HELP!! Over boosting with stock soleniod back on..
After trying on greddy profec-a and I wasn't to happy with it!! I decided to go back to stock setup lines and soleniod pills!!! And now I am gettinig over boost
Now does it matter the direction of the pills??
Yes, you must re-install the exact OEM stock boost lines in the exact configuration they were originally. You cannot use other lines or try to mess around with the pills. The short hose with the red tip should go to the wastegate nipple, and the other short hose (has a pill in it) should go to the turbo nipple.
Ya I did put back he stock lines!! But after SEARCHING I learned about the lil pills in the stock lines!! So after about what seemed like 100 time of trying the lines in differnt ways I decide to check the pill And I guest when I removed the stock lines to install my BC I must have mest with the pill and it was blocking airflow!!!
So after setting it in right it works...
On the solenoid side, the hose with the white dashes goes to the top nipple of the solenoid and intake. The hose from the T goes to the bottom nipple.
FS[SouthEast]: 3 port BC soleniod used ***Cheap***
Yoga_EVO
15
Mar 6, 2015 01:00 PM
Optiblue
26
Feb 20, 2014 01:05 AM
