Help! My RPMs are dropping at wot
Old Aug 2, 2006 | 10:59 AM
RobDogg's Avatar
I searched and found that when your clutch is slipping your rpms will rise. This is not my problem my rpms will slow when full boost comes on and drop 200rpms then climb back up a moment later. I'm very concerned
Old Aug 2, 2006 | 11:02 AM
Warrtalon's Avatar
That's the same thing. It's slipping at peak torque, then falling back down and catching.
Put it in 6th on the highway at 2000rpm and floor it. Keep it floored and see if you feel the clutch slip right when the boost builds. The typical way it works is you get a quick rise in rpms without accelerating, then when the clutch catches, the rpms drop back down and you begin to accelerate normally again.
Old Aug 2, 2006 | 11:09 AM
RobDogg's Avatar
I can deal with it if it's just the clutch
thank you
Old Aug 2, 2006 | 11:11 AM
BenjyJ's Avatar
You should really get a new clutch though, you're not getting the performance you should be and you'll need one soon anyways.
Old Aug 2, 2006 | 11:17 AM
PANGES's Avatar
What WT said. Same thing happened to me and my clutch gave out about a week later
Old Aug 2, 2006 | 11:28 AM
4Gsixty3's Avatar
Definately its yr clutch giving out! time fo ACT or Exedy!
Old Aug 2, 2006 | 11:38 AM
Assassin's Avatar
Been there done that. It's slippin.
Old Aug 2, 2006 | 11:13 PM
00ssap1's Avatar
ya, same thing happened to me. A week later i couldn't drive up hills new clutch time!
-dan
03 evo gsr rr
Old Aug 5, 2006 | 04:43 AM
deegaw11's Avatar
damn the samething is happening to me now...car drives perfectly normal and strong but when i hit boost the rpm just raises like 1k and then drops and catches again...i had no idea it was the clutch until i read this =(
JorgeAvila
Oct 9, 2014 04:05 PM
btownsoccer22
Oct 21, 2011 10:31 PM
joedr
Aug 22, 2008 01:11 PM
GOTMEALANCER
Lancer Troubleshooting
Jul 4, 2006 04:58 AM
Arithmetic
Jun 12, 2005 10:38 PM
