Check my setup..what else do I need?
Old Aug 3, 2006 | 05:54 AM
11secEVO7's Avatar
Cool Check my setup..what else do I need?
Engine
CP pistons
Crower Rods
Clevite main and rod bearings
ARP head studs
Greddy 1.2mm head gasket
HKS 272 camshafts
HKS cam gears
HKS valve springs
HKS twin power
GT37R turbocharger by AMS
Shearer Motor sports manifold
Tial 38mm wastegate
AEM EMS
AEM 3.5 bar sensor
1000cc precision injectors
AMS fuel rail
Flex-A-Lite engine fan 12”
Walbro 255lph fuel pump
RPS twin disc carbon/carbon clutch w/
Cynergy Flywheel
K&N filter
Spearco intercooler (33 x 14 x 3.5)
Holley NOS system (10lb bottle)
Nitrous Express N-tercooler chiller (5lb bottle)
Koyo aluminum radiator
Weapon R engine damper
Custom 3 inch downpipe and exhaust
Tomei timing belt
Turbo XS blow off valve
Aeromotive Fuel pressure regulator
Road Race Balance shaft removal kit
Logic Performance oil catch can
Buschur racing shifter bushings
Zaklee Clear Cam gear cover
NGK 8’s spark plugs
Buschur Racing braided clutch line
and what time do you guys think is possible with these mods..
keep in mind I will be using street tires and I lift to shift
Old Aug 3, 2006 | 06:07 AM
staatz's Avatar
umm..high 9s?..wow, what are the numbers for it?
Old Aug 3, 2006 | 08:35 AM
Ang Wen Yan's Avatar
Get an alky and DR.Pratice your driving and try to hit 9's.Good luck.
11secEVO7's Avatar
^that's the sad thing!
there's no 4WD dyno here!
so it's all road tuning...and even that's crap cause the roads are terrible and short and clustered with cars day or night!
I'm hoping to take it to the drag strip soon though......
Old Aug 3, 2006 | 08:37 AM
smokeyonline's Avatar
Very inpressive list. The only things I would change are the injectors, (you may want to go with some 1200cc or 1600's to feed that 37R) and that intercooler. you should go with either a Buschur race ar AMS race FMIC. Oh and upgrade the wastegate to a 44mm. Nevertheless, very impressive. Good luck .
Old Aug 3, 2006 | 08:42 AM
Dynofrk666's Avatar
I've got pretty much the same setup going, but my list doesnt look as extensive lol
Old Aug 3, 2006 | 08:44 AM
scorke's Avatar
This car is for sale, no?
Scorke
Old Aug 3, 2006 | 10:10 AM
11secEVO7's Avatar
yeah...
but I figure while I wait for it to sell I'm gonna try to set another record for myself
Old Aug 3, 2006 | 10:36 AM
Stew's Avatar
Drivetrain work???????
Old Aug 4, 2006 | 07:16 AM
11secEVO7's Avatar
^^hmmm.....like what?
rear axles
or modified gearbox from shep
Old Aug 4, 2006 | 08:00 AM
Stew's Avatar
I would say since that turbo is a 700 awhp turbo, you'd need gearbox upgrades and probably a set of rear axles. TRE or Shep for the Tranny, and Driveshaft Shop for the Axles.
