Is this correct for stock boost? (short vid link)
Old Aug 4, 2006 | 11:49 AM
Peteypab2133's Avatar
Question Is this correct for stock boost? (short vid link)
I installed the boost gauge that i got today real fast, but didnt have a mount for it so i rigged my own (no flaming its temp).. After the install and first runs i noticed its spikes kinda high at certain times. Its gone to flat 25 a few times and drops back down and holds around 18... on the video it goes to around 23 or so from what it looks, but for stock boost untill i get it tuned, is this normal?
I only have a few exhaust parts.
http://www.youtube.com/watch?v=I6f98VvYa14
Check it out tell me if its ok for stock boost levels.
Installing the MBC tomorrow or later tonight, will it help to hold it at 18/19/ or 20 PSI?
Old Aug 4, 2006 | 11:51 AM
bluebanana23's Avatar
what kind of gauge is it? Doubled checked the install was correct and no kinks in the line?
Old Aug 4, 2006 | 12:04 PM
whitersevo's Avatar
well from what i know is that the exhaust will give u 1psi more of boost.. but as for the spiking that is normal... but you r boosting a little low i am bout 20 21 psi stock..
Old Aug 4, 2006 | 12:05 PM
checked and there were no kinks, but i did T it from the FPR... Is that okay? in 3rd it holds 20PSI for a while and when i shift to 4th at any given time it jumps a little, i guess it does the same for 3rd but it hops to 25 then down to about 21, then 20 for a while till it goes to about 17
Old Aug 4, 2006 | 12:06 PM
Ultimateone's Avatar
A spike to 25 isnt low....
Old Aug 4, 2006 | 12:16 PM
I dont know if this will make a difference, but i also have a DNP manifold and DNP 02 housing on top of the TBE with no cat..
Old Aug 4, 2006 | 12:47 PM
VIIII's Avatar
do a boost leak test,i would think the mbc would solve it also
Old Aug 4, 2006 | 12:50 PM
ok, thanks for the input... ill be putting on the MBC tonight or first thing in the morning.. will have a follow up once i get it solved.
Old Aug 4, 2006 | 12:57 PM
Spaceball 1's Avatar
100% normal for stock boost control. Car sounds great. Get that MBC on there so it holds steady at 22 to 20. Your gauge maybe off alittle, mine is off by 3 psi at 25psi. Aem pressure sensor says 22psi and guage reads 25psi. Which one you gonna look at a $35 guage or $200.00 pressure sensor.
Old Aug 4, 2006 | 01:07 PM
evo gerg's Avatar
what other mods do you have on ur car?
Old Aug 4, 2006 | 02:09 PM
elhalisf's Avatar
with those exahust mods, your spike is normal. stock boost easily tapers down to 18-19psi.
