How Long Has Your Exedy Twin Plate Lasted?
Old Aug 6, 2006 | 04:40 PM
supersupra's Avatar
Can you speed shift with it, or it jams like other clutches?
Old Aug 6, 2006 | 04:44 PM
evocanival's Avatar
By speed shift, do you mean leaving the pedal to the floor while quickly clutch kicking and shifting. Some poeple call it different names, thats why i ask. If so then yes I do, but only 3rd -4th. 1st-2nd I only have the gas halfway depressed! Hope this answeres your question
justchil's Avatar
Right around 30K miles. Not one issue other than a little decel chatter (no big deal)
Stock turbo 300hp (br dyno) for 80% of those miles (+restrictor). 20G 330-345hp for the last 20% (-restrictor). Probably 40-60 drag passes.
LOVE the clutch and will buy another when this one dies. I can shift REALLY fast with this clutch on stock drivetrain. I'm still using the stock shifter + poly bushings & brass underhood bushings with the resrictor removed.
Old Aug 6, 2006 | 04:45 PM
EvoDan2004's Avatar
this may be a dumb qestion but how many different types of twin disc's do exedy make. witch one seems to be the best?
also are you guys useing aftermarket flywheels. what one's you got?
Old Aug 6, 2006 | 05:01 PM
justchil's Avatar
Ceramic
Ceramic HD
Carbon
^^ I think. They include the flywheel. You definately don't want carbon on a daily driver.
Old Aug 6, 2006 | 06:46 PM
Recks's Avatar
Hmm don't mean to steal the thread but has anyone heard of ogura/ orc clutch? I hear those are excellent clutches... My tuner said that exedy = baby and ogura = daddy lol!!!!
Old Aug 7, 2006 | 08:34 PM
supersupra's Avatar
Yes, shifting at 75000 rpm with the pedal to the floor. Most of the aftermarket clutches, I've been told, jam and you miss the shift,loosing the race or making a bad run.
Old Aug 7, 2006 | 08:38 PM
cneio's Avatar
Originally Posted by Zeus
Don't get a carbon for a street car... regardless.
A friend down here in Brazil got a carbon for his street car (EVO 7) and he keeps complaining that it slips all the time, specially in 4th and 5th gear.
He said his "break in" period has not ended yet.
I have done at least 30 hard launches (reved it up to 6000rpm and let go off the gas) with my Exedy Twin and so far so good: holds great, no slipping and great for daily use!
Last edited by cneio; Aug 7, 2006 at 08:40 PM. Reason: forgot to add the comments on the twin plate
Old Aug 7, 2006 | 08:42 PM
EvoDan2004's Avatar
Originally Posted by justchil
Ceramic
Ceramic HD
Carbon
HD for heavy dudy???
would that be the best street/drag cluch for say 450hp range
thanks
Old Aug 7, 2006 | 09:23 PM
Zeus's Avatar
The carbons were never designed for daily driver duty. If you drive it daily, come see me in 5-10k... if it is a weekend race car, well, that's more what it was designed for.
BTW you might want to get with MattGold when they wear out. He used to work for Exedy, and is now with someone else... but still hooked up. He also does not recommend Carbons for daily drivers.
Old Aug 7, 2006 | 09:26 PM
Zeus's Avatar
thanks
I'm running the HD right now thanks to Cal at Speed Element. I think other than the clatter, it is the hot ticket for up to a 500 or so hp street ride.
Old Aug 10, 2006 | 02:09 PM
PKEVO8's Avatar
yea i've heard of ogura. Do they even sell in america?
Old Aug 13, 2006 | 08:28 PM
sccavee's Avatar
I think mine went out today at the shootout. Got over 30,000 miles but not really many track runs.
Old Aug 14, 2006 | 12:11 PM
EVOlutionary's Avatar
ETD Ceremetallic.
34,000 street miles
120-140 Autocross runs (usually with a full launch, ask my passengers!)
10-15 Quarter Mile passes
It might finally be starting to slip a little bit. I will find out for sure tonight. BTW, my stocker went out at 12,000 miles.
EVOlutionary
Old Aug 29, 2006 | 10:22 PM
supersupra's Avatar
Originally Posted by EVOlutionary
ETD Ceremetallic.
34,000 street miles
EVOlutionary
ok ok ok I need to know. You launch at 6k in the autox? does it gives any advantage (well I guess .5 secs)
I see that you have a 20G. How good is it for the autox.
The question is because I havent change my turbo because the autoxs but I see you go to a few with it.
Are those the cams that give better spool time?
Let me know.
txs
