just installed 20g 9 5 overboosting?
Old Aug 6, 2006 | 07:16 PM
dustin03's Avatar
how would I check that I mean it should come ajusted I though
VTECH8TR's Avatar
Dustin,
YOu definitely have something wrong. How in the heck are you hitting 35 psi.
1. Check the pretension on the wastegate arm. Loosen the 2 12mm bolts and check the tension, it should be snug but not to tight.
2. Run a hose from the wastegate nipple and t it into the BOV and intake manifold conneciton.
3. Did you eliminate the stock Boost Solenoid?
Old Aug 6, 2006 | 07:17 PM
dustin03's Avatar
I will check
Old Aug 6, 2006 | 07:19 PM
EvoDan2004's Avatar
Originally Posted by VTECH8TR
Dustin,
beet me to it. let us no when you get back
Old Aug 6, 2006 | 07:21 PM
dustin03's Avatar
well I have to go out and buy a t cause I don't have one at the house and I have no way to check the acuator cause I have no jack here.
Old Aug 6, 2006 | 07:22 PM
dustin03's Avatar
do you think wally world would have any?
VTECH8TR's Avatar
Check out those 3 things and let us know .
Old Aug 6, 2006 | 07:24 PM
dustin03's Avatar
how do I eliminate the stock Boost Solenoid ?
Old Aug 6, 2006 | 07:33 PM
jj_008's Avatar
By using a MBC. I don't think there is anyway you could hit 35psi w/ that turbo. You may want to find another boost gauge to use.
Old Aug 6, 2006 | 09:41 PM
dustin03's Avatar
well I have to wait tell tue when I get off work to try and fix this. I will let you all know.
Old Aug 6, 2006 | 09:49 PM
freshevo8's Avatar
35??? I didn't even know it could go that high, much less BEYOND 35. I also can't imagine holding down the accelerator long enough for it to get that high. You could blow your motor with ONE pull to 35psi, so don't do that again!
Did cross up the boost lines during the install? Does it have the high boost actuator? With that, you can't go below 24-25psi or so, but it doesn't cause 35+.
i know of and road in an evo9 mr with a 20g-5 that was boostin 35psi on the stock motor(arp headstuds/280exhaust cam) but tuned on 100oct. with the ecutek. frickin car hauled @ss! it was maximumboost old evo9. blew out a syncro and screwed the tranny with that triplecarbon clutch he had in it car was nice though. looked bone stock except for the forge bov under the hood.
Old Aug 6, 2006 | 10:37 PM
dreaminevo's Avatar
35 psi wont blow your motor on one pull . i boosted my stock motor/ turbo to that 3 times trying to set my boost controller . the only thing that it messed up is it stretched the spring in the wastegate so it only hold 12 psi without the controller
Old Aug 7, 2006 | 05:04 AM
C6C6CH3vo's Avatar
With due respect, I think you answered your own question
thats the thing I don't even have my mbc in yet
Go find out fully how the system operates and go from there
Old Aug 7, 2006 | 05:08 AM
dustin03's Avatar
you should not have to control boost with a mbc it should run on a stock setting
Old Aug 7, 2006 | 05:26 AM
C6C6CH3vo's Avatar
All the MBC does is send air to WGA when pressure is enough to push it's spring (set by turning knob - tighter - more boost). The WGA will then move and less exhaust will spin turbo. It's like a balancing act to maintain steady psi
The aftermarket MBC system is primative, but somewhat reliable at maintaining desired psi. The OEM setup is superior but only provides OEM performance (taper)
If boost is uncontrolled the WGA likely isnt getting air, is damaged, way out of adjustment, or linkaged is bound
