best bang for the buck mod
Old Aug 12, 2006 | 03:32 PM
Ackerson's Avatar
I'm looking to get a little more out of my '03 without breaking the bank.
I currently have a 3" turboback exhaust, ARC air box, Turbo XS Utec(that I'm selling), EBC at 24 psi, and I just ordered a methanol injection kit.
What else can I do for under $500 that will get me a little more power? I was thinking cams or a larger hotside, or mabe both if I can justif spending the money. How much does the bigger hotside help?
Old Aug 12, 2006 | 03:40 PM
JDMevoBOOST's Avatar
a tune
Old Aug 12, 2006 | 03:42 PM
thisxguy's Avatar
yeah...a good tune
Old Aug 12, 2006 | 03:43 PM
thisxguy's Avatar
cams are a good idea. but you'll NEED a tune after installation. but, if you throw a few extra dollars into that...get some cams and cam gears (used is fine..but make sure they're in good condition) and a tune.
fraser91084's Avatar
fuel pump and tune
Old Aug 12, 2006 | 03:51 PM
ATRAX's Avatar
Cams and then a flash. May set you a little over you're $500 spending limit though depending on which cams you get.
Old Aug 12, 2006 | 03:52 PM
bigtymer's Avatar
Def. a tune
Old Aug 12, 2006 | 03:59 PM
fromWRXtoEVO's Avatar
Tune it.
Carlos
Old Aug 12, 2006 | 04:15 PM
EVOIXMR8916's Avatar
bump on the tune...
Old Aug 12, 2006 | 06:37 PM
Ang Wen Yan's Avatar
Tune,Fuel Pump and possible some cam
Old Aug 12, 2006 | 06:50 PM
Tpayne84's Avatar
24 psi on pump gas, with no tune, no fuel pump, and no Alky/meth????
Old Aug 12, 2006 | 08:59 PM
Ludikraut's Avatar
Tune it ... ECUflash + TACTRIX cable ~$130 plus time for a good tuner.
l8r)
Old Aug 12, 2006 | 10:32 PM
Ackerson's Avatar
It's currently tuned with the UTEC, I have something else I'm going to be using, so I'm selling it. So the tuning is all taken care of. Are there any advantages to running a larger hotside, or should I just get the cams?
Old Aug 12, 2006 | 10:45 PM
Turbolover's Avatar
the SEARCH button!!!
ITS FREE
Old Aug 12, 2006 | 11:00 PM
evolusion's Avatar
^and evom.
save a motor reading some stickies.
