whats better... 5 speed or 6 speed?
I would think that if you were hard core road racing your Evo, an aftermarket tanny cooler may be in order. ARC makes a Fantastic one. WARTALON is also having his tranny rebuilt, he busted 4th in his 6 speed. Change your gear oil often, invest in a Gear oil temp gauge, heat kills these things you know.
FWIW the 5 speed has to be stronger as there are less parts in the same gear box, I would immagine certain gears are a lil thicker since there is extra room.
That gear above looks like only half the gear (lower half) grabs before it settles, probably stripping it. If it were thicker it would have more to grap on.
[QUOTE=Tsurugi-san] those laps always ended with the RS in the lead (lower weight 5-speed), followed by the MR, and then the GSR. So given almost equal weights, 6 speeds win in the head to head.
The MR has Bilstiens, that probaly has more impact than the 6 sp.
Originally Posted by Evo8yurAMG
i have no idea how the MR could get worse HIGHWAY MPG...
Plus I hear the 5 speed has a higher top speed. I read like 163 is for the 6 and 167 for the 5
WTT[West]: Five Speed to Six Speed
chronohunter
16
Mar 29, 2016 06:12 PM
jinhaingEVO
Oct 30, 2006 04:13 PM
