Car nudges when putting into 1st from stop???
Old Aug 20, 2006 | 05:12 PM
newimportowner's Avatar
Mine does this at times with the stock clutch.
Old Aug 20, 2006 | 05:40 PM
azredevo's Avatar
x2. do you guys also notice that when it happens, it is a tad more difficult moving the shifter into first gear?
Old Aug 20, 2006 | 06:06 PM
Danny23's Avatar
adjust the clutch so there is no free play at all on top,then adjust it so you have around 3-5MM play on top and you should be fine.
Old Aug 20, 2006 | 06:12 PM
elhalisf's Avatar
mine does that no matter how high i adjust the clutch.
Old Aug 20, 2006 | 06:40 PM
scottatyamaha's Avatar
Yes....sometimes....it kind of notches in.
Old Aug 20, 2006 | 06:43 PM
I will try this in the morning...thanks
Old Aug 22, 2006 | 04:34 PM
evo150's Avatar
i have 40,000 miles on my clutch and just adjusted mine up. what is considered "free play"? when measured with a tape measurer i measured 5mm from the top to the first amount of resistance.
Old Aug 22, 2006 | 05:31 PM
Rnm's Avatar
Rnm
x2
I just noticed it today while driving, but the shifter went into 1st with ease, so I'm not sure if there is a problem...
Old Aug 22, 2006 | 05:36 PM
I adjusted mine out until there was only like 3-4 threads showing and it went away.
Old Aug 22, 2006 | 05:51 PM
evo150's Avatar
on a stock clutch should i be adjusting out or in? no grinding issues just a bit notchy
Old Aug 22, 2006 | 06:13 PM
adjust it so that the clutch pedal is slightly higher than the brake pedal
Old Aug 22, 2006 | 06:27 PM
evo150's Avatar
thanks
