Car nudges when putting into 1st from stop???
Old Aug 19, 2006 | 09:26 PM
scottatyamaha's Avatar
Its weird, it does not happen all the time but sometimes when I put my car into first when i am completly stopped the car barly nudges forward some. It does not continue to move after, just that initial small nudge. Also it is not hard to put it into gear when this happens.....it goes right in. I have a ACT street clutch and have adjusted my pedal awhile ago and everything shifts smooth and the pedal lets out towards the top. Should i adjust it again, if so what way or should I rebleed the system or is it something with my clutch engaugement....i just want to make sure that the clutch will not wear out early if something is not right. thanks for the help
Old Aug 19, 2006 | 09:28 PM
EvoEntropy's Avatar
Happens to me too, idk if it matters, but i have the same clutch
Old Aug 19, 2006 | 09:30 PM
scott yo's Avatar
i have the act clutch and mine does it also im assuming it isnt fully engaged which doesnt make sence because it grabs almost all the way out if someone who knows why this is caused chime in im interested
Old Aug 19, 2006 | 09:36 PM
NastyEVO's Avatar
I have the same issue with my Exedy HD Twin.
Thats what i was thinking...
Old Aug 19, 2006 | 10:36 PM
VIIII's Avatar
where is the pedal engaging?
Old Aug 19, 2006 | 10:39 PM
scott yo's Avatar
i have seen in other threads that the ACT street clutch engages really late for everyone who has it. it just nudges it never grinds wierd!
Old Aug 19, 2006 | 10:46 PM
boostedwrx's Avatar
Usually means the clutch is dragging.
Old Aug 20, 2006 | 01:42 AM
gregfromblur's Avatar
ACT here. same issue. but... it did this on my first Gen as well, did it in my hatchback, and even in my Starion. All with ACT clutches. it is werid... cause it only happens a few times here and there. my buddy has the same thing on his Evo with an Exedy.
Old Aug 20, 2006 | 08:58 AM
I think I am going to adjust my pedal down some to see if that helps with pushing the clutch all the way so that is does not nudge....because if it does this going into first, it is probely doing when we are shifting into other gears also. That could account for why sometimes my shifts feel smooth and others it can feel somewhat notchy. I think I may have the engaugment set too high.....anyone think this?
Old Aug 20, 2006 | 09:11 AM
spudlus's Avatar
Sounds as if you guys have a clutch engagement issue. Try lowering the point of engagement on the clutch pedal as see if this works.
Old Aug 20, 2006 | 09:15 AM
laakness's Avatar
I don't have any lurching forward, but I have adjusted my clutch pedal down some (same height as brake pedal when not touching either) and my engadgement is high in the pedal as well. It feels hard and that it's fully engaged it is just that it engadges just before its all the way out.
edit: ACT Street with light flywheel
DRFTKNGG's Avatar
Pedal adjustment is too close to engaging. Dragging, or creeping is caused when improper adjustment of the pedal. "Thanks UTI "
Old Aug 20, 2006 | 09:19 AM
So should I adjust the pedal down some?
Old Aug 20, 2006 | 05:01 PM
I adjusted the pedal out some so that there are only a couple of threads showing...other than having to relearn where the clutch let out...I think it may of cured my problem. I just want to make sure that the clutch is not dragging and is going to premature wear.
