Why are ported or Large Throttle bodies shunned upon or deemed useless?
Old Aug 23, 2006 | 07:31 AM
  #46
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Originally Posted by Soon2BEVO
LOL your crackin me up. I have many more but not for general audience
While you guys keep talkin about throttle bodies I'm gonna stare at his avatar...
Old Aug 23, 2006 | 08:39 AM
  #47
Jeff_Jeske's Avatar
Originally Posted by KevinD
how is it that you maxed out the stock turbo with only cams, filter and exhaust, when i have the same mods and am nowhere near maxing it out? what boost are you running? try turning up the boost and i bet you see increased massflow rate....
It all comes down to airflow....the stock 16G is tapped out at 42LBS.... if you see 42LBS at 22psi turning the boost up to 27psi isn't going to do any good. Airflow = Power. Boost = Heat.
I too have maxed out the stocker.
Old Aug 23, 2006 | 09:16 AM
  #48
KevinD's Avatar
thanks for pointing out the obvious there jeff :P
my point is, he said he maxed out the stock turbo (you too), with only intake, exhaust and cams. i am saying this is highly unlikely as i have the same mods and have not reached the max airflow of the turbo. i know for a fact the stock turbo can run 28 psi.... which assuming equal VE and engine speed, means you have a higher mass flow rate with a reasonable density ratio out of the intercooler. of course boost = heat. thats what an intercooler and methanol injection is for. stock turbo is good for 400whp as some have shown. cams, exhaust and intake is not 400hp.
Old Aug 23, 2006 | 09:53 AM
  #49
Soon2BEVO's Avatar
Originally Posted by kjewer1
This applies to all of the other airflow related mods I have done to the car. Basically, I maxed out the stock turbo with a filter, exhaust, and cams. The car went 12.1 at 113 or so. Since then, I've done the LICP, UICP, 1g BOV, FMIC, bigger filter, etc, and went 12.0 at 114. The airflow has not changed. I attribute the miniscule gains I got to the new clutch. I expect an upgraded TB would still be worth about nothing.
I dont think its too fair to say the turbo was maxed out when you were running 113-114mph. People on here (like myself) have gone 116mph on the stocker on straight pump. I am basically maxxed out at where I am since I have just about all the bolt-ons. Regardless, my next mod will be a turbo upgrade, not a bored TB/intake manifold.
Old Aug 23, 2006 | 10:01 AM
  #50
its so beautiful....
Old Aug 23, 2006 | 10:10 AM
  #51
bolsen's Avatar
Not sure where you guys are going with all that, but to answer the original question.
Ported / bigger TBs aren't big here because it's usually a mod that won't make much power unless you have other things to back it up. It's a good mod, it's just not a mod for someone that has trouble picking on o2 housing.
Old Aug 23, 2006 | 10:12 AM
  #52
KOEvo's Avatar
I'm about to bust out a newb question, flamers skip this post.
How do you measure how many lbs of airflow you are currently running? I checked my EcuFlash datalogs and didn't see anything seeming related.
Old Aug 23, 2006 | 10:32 AM
  #53
KevinD's Avatar
with a mass airflow meter. the stock one measures it, however i beleive the output will be in Hz whereas you will need to find a conversion from Hz to lb/hr, lb/min or whatever relevant mass flow rate units you desire.
Old Aug 23, 2006 | 12:10 PM
  #54
Mad_SB's Avatar
Its a pain in the ***. But that wasnt my point. Buschur got the 8-10whp from taking port maching the intake manifold to the bigger TB. Unless youre going tio port it yourself, then taking off the Intake mani is huge PITA and for $350+ plus that hassle, 7hp doesnt seem that worth it.
not to nit pick, but the 8-10 was from putting the 65 on the ported mani over what the stock tb did on the ported mani.
I agree it is a lot of work and probably not worth doing unless you do the manifold as well. I think in the buschur thread the mani was extrude honed and port matched both to the 65 and the head.
Old Aug 23, 2006 | 12:13 PM
  #55
Mad_SB's Avatar
[QUOTE=Jeff_Jeske]It all comes down to airflow....the stock 16G is tapped out at 42LBS.... if you see 42LBS at 22psi turning the boost up to 27psi isn't going to do any good. Airflow = Power. Boost = Heat.QUOTE]
+1
Old Aug 23, 2006 | 12:25 PM
  #56
olsookie's Avatar
Soon2BEVO, gotta love that avitar!!
Old Aug 23, 2006 | 12:46 PM
  #57
Soon2BEVO's Avatar
Thanks. Ive gotten a ridiculous overwhelming response since putting it there. PM's, IM's, and shout-outs everywhere
  #58
Jeff_Jeske's Avatar
You cannot determine if a turbo is maxed out by MPH or DYNO. Weight shifting environmentals all affect those numbers. Running a snail outside of it efficiency range will have next to no returns.
As for the TB.... if the TB is bigger than the IC piping I doubt its gonna do much good. Furthermore it will require more tuning of fuel trims and idle control.
Old Aug 23, 2006 | 12:52 PM
  #59
well make us happy and show us the bodess it belongs to!
Old Aug 23, 2006 | 12:57 PM
  #60
Soon2BEVO's Avatar
Geez fellas relax lol. I have posted pics of her before. To be specific, in the girlfriends pic thread a while ago. https://www.evolutionm.net/forums/sh...&postcount=109
