Why are ported or Large Throttle bodies shunned upon or deemed useless?
Old Aug 23, 2006 | 01:25 PM
  #61
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
i just straight up couldn't handle that
Old Aug 23, 2006 | 03:16 PM
  #62
Jeff_Jeske's Avatar
Originally Posted by Soon2BEVO
Geez fellas relax lol. I have posted pics of her before. To be specific, in the girlfriends pic thread a while ago. https://www.evolutionm.net/forums/sh...&postcount=109
OMG I hate you.
Old Aug 23, 2006 | 03:21 PM
  #63
kjewer1's Avatar
I dont think its too fair to say the turbo was maxed out when you were running 113-114mph. People on here (like myself) have gone 116mph on the stocker on straight pump. I am basically maxxed out at where I am since I have just about all the bolt-ons. Regardless, my next mod will be a turbo upgrade, not a bored TB/intake manifold.
As Jeff mentioned, you can't determine if a turbo is maxed out by times or HP. Different people and setups get different amounts of power out of a given mass airflow rate. Weight also plays a role, etc. Look at Curt Brown for a good example of someone getting way more than the next guy at the same airflow. His 10.59 stock turbo isn't flowing any more than my 12.0 stock turbo.
how is it that you maxed out the stock turbo with only cams, filter and exhaust, when i have the same mods and am nowhere near maxing it out? what boost are you running? try turning up the boost and i bet you see increased massflow rate....
It would be impossible for me to add more boost, since I don't use a boost controller. At the track I pull the vac line off the WG actuator. The internal gate does not blow open either. The turbo makes the most flow it possibly can, and the boost is simply what is left over (what the motor doesn't flow). This illustrates how increasing flow through the motor on a maxed out turbo simply lowers boost.
It's also worth noting that on my own car, with the turbo maxed out, mph can vary from ~110 to 115. That's quite a bit of variation, all from the tune and type of gas I am running. A local club member with the same exact mods as me, and the same or very similar settings in DSMlink, has run as fast as 11.7 at 119 mph. And then consider that at the same 42 lbs/min plus nitrous my car went 122.
The point is that my statement about the turbo being maxed out is just that, a statement about the turbo being maxed out. You really can't infer too much else from it.
Edit> Run with no WG signal at your own risk. It could be pretty hard on the turbo.
Old Aug 23, 2006 | 03:51 PM
  #64
WhiteEvo05's Avatar
Originally Posted by LetItBreath
its so beautiful....
Your prior interjections and then this...I haven't laughed so hard for a long time!
Old Aug 27, 2006 | 03:44 PM
  #65
kmcconn9's Avatar
so with a bigger turbo, with 2.5" pipes..would this warrent the ported tb and mani?
Old Sep 25, 2006 | 02:20 PM
  #66
MitsuJoe's Avatar
No conclusive evidence after 4 pages. Wow come on guys...
Old Sep 25, 2006 | 02:28 PM
  #67
Aby@MIL.SPEC's Avatar
I plan on conducting a 65mm vs 60mm compare next month when this dyno shop opens up down the street from me.
Old Sep 27, 2006 | 03:10 AM
  #68
kjewer1's Avatar
We're not here to serve you, go do the testing yourself. Your post adds nothing to this thread.
Old Sep 27, 2006 | 08:26 AM
  #69
MitsuJoe's Avatar
It was an easy way to bump. I trust WOT to provide something and if it is good then he will get my money.
Old Sep 27, 2006 | 08:58 AM
  #70
althemean's Avatar
has anyone had any sticky throttle issues with the larger TB? The last time I installed one on my z-car, the linkages were sloppy and I needed to add helper springs. Granted it was on older z-car....has this happened to anyone with an Evo TB upgrade?
Old Sep 27, 2006 | 11:30 AM
  #71
MitsuJoe's Avatar
I had a stock TB blow out the seals and the symptoms to it where it being stickey when it was cold. Not sure if it is related to what you are asking although it is a problem with the TB.
Old Sep 30, 2006 | 06:14 PM
  #72
Flyin EVO 2's Avatar
Another key fact that nobody is touching on is rpm. If your motor, cams, turbo, and intake manifold are going to make power past 8,500 rpm then a larger throttle body is going to help exploit this as well. You would also need a better flowing intercooler, and a larger upper intercooler pipe. Anything larger than a 35r would benifit. If your on a stocker or a quick spool 30r don't waste your time.
EndlessRed
Evo X Dyno Results
10
Feb 4, 2013 04:58 PM
Slobaru07
Dec 4, 2011 05:37 PM
GTVEVO
28
Oct 31, 2010 03:53 PM
Whoop_ass
16
Sep 11, 2008 02:42 AM
IDRINKV8
Nov 21, 2005 05:34 PM
