which stroker kit would you guys go with??
Old Aug 23, 2006 | 01:47 AM
Vishnu_Evo8's Avatar
Ive been really considering going with a 2.3l stroker. I have checked out ams and the sbr kits. They both look very similar and i know there are lots of fast cars running both kits. Are there any notable differences between the two, or are they pretty much the same?
or.. is it recomended to buy a pre assembled block?
Old Aug 23, 2006 | 03:17 AM
trinydex's Avatar
i'd actually get a jam... but i realize that's not what you asked.
Old Aug 23, 2006 | 03:19 AM
smokedmustang's Avatar
Pre assembled AMS stroker, don't pass go until you get that one! What turbo are you going to hang off of it??
Old Aug 23, 2006 | 10:41 AM
8URVTEC's Avatar
I am doing 2.3 with race head and 3037s! I will let you know once everything is done....
Old Aug 23, 2006 | 11:24 AM
3240's Avatar
No, no, no...go with the pre assembled de-stroked to 2.2L AMS 4g64 engine. Coolest set up available IMO.
Old Aug 23, 2006 | 11:36 AM
ibanez_926's Avatar
If you are 100% confident that you can build the motor, then you will save about 1200 + the shipping of your block.
Personally i would go with AMS or Buschur. When that time comes around for me i will go with the AMS stroker just because they are close and i can just disassemble everything and bring the block to AMS to build the motor.
Old Aug 23, 2006 | 11:45 AM
SKILMATIC's Avatar
To tell you the truth they are pretty similar both will net you the around the same power gains dependong of course on the supporting mods.
Old Aug 23, 2006 | 12:55 PM
i didnt check the buschur one yet, so ill go look into that. As for putting it all together, i have a local shop (full function) that is real good at building 4g63s.. so that shouldnt be an issue.
Old Aug 23, 2006 | 01:01 PM
Tpayne84's Avatar
Give Greg at GSC a call (843-852-2727) . i was talking to him today about their stroker kits. they sound amazing!!
Old Aug 23, 2006 | 01:08 PM
Derek888's Avatar
Jam 2.3 :d
Old Aug 24, 2006 | 04:40 AM
ZyBeR's Avatar
It depends on your goals..
If you like to keep cost down go with a 4G64 crank, some cheep rods and pistons. Balance everything and step up to 85.5mm cylinder diameter. That will give you ~2.25l and a 100mm stroke for close to nothing.
Next if you like all other Americans like to have the largest displacement possible you can get a custom crank with a 102mm stroke, some nice Carillo H-beam rods and good CP pistons. For example you can order 102mm cranks from Eagle, Crower and Doug kiddy. This will give you a little bit more than 2.3l depending on cylinder size. It can be a mid price to high price project (Doug Kiddy is very expensive but one of the best out there).
My choice would be (and is) JUN 2.2l kit. It's very expensive with a retail at $6500 but you get it all! Billet steel crank with 88mm stroke, light pistons and rods made for reving. This is the kit many racers in Japan uses.
Just below JUN comes TOMEI, they have the same stuff but with a bit easier design and not so much R&D as JUN. It's also a 2.2l kit with billet crank, 88mm stroke and so. I know my friend Jeff over at http://www.500WHP.com can get this at a good price.
All abow choices uses your stock block with some machining.
There is also the 4G64 block conversion that RnR have but that's another story.
Remember: The longer stroke, the bigger displacement, the less you can rev.
High HP = High rev = Harder to drive on the street.
The best (according to R&N) displacement/rev is 2.2l
Old Aug 24, 2006 | 04:43 AM
M10's Avatar
M10
Originally Posted by Reine
Guys.... If you want to play with the big boys, there is only JUN...
And the big price tag.
For the average joe i say go with AMS or Buschur's stroker kits. Can't go wrong either way.
Old Aug 24, 2006 | 08:55 AM
RallySport Direct's Avatar
Silver Sponsor
We actually have a stroker kit that we pieced together. If you have a good machine shop and can afford the downtime of your car it would be cheaper to rebuild your motor. Mitsu charges a arm and a leg for a empty block.
http://www.rallysportdirect.com/shop...it-p-2624.html
Old Aug 24, 2006 | 03:24 PM
FlyNavy's Avatar
I've got a 2.4 Brian Crower Pro kit inbound. I'll let you know how it goes!
Old Aug 24, 2006 | 03:33 PM
Rcebowl's Avatar
ummm that's not always 100% true... i mean some of the highest hp Evo's are still using 2.3's..... i know Chris (the black AMS car) with his gt42r was hitting ...what? 926awhp with a 2.3
and correct me if im wrong (which could be) but the Highest hp evo right now is using a stroke'd 4g63?
EDIT dont get me wrong i know most the highest hp Evo's are destroked evo's but not all of them is all i'm saying
