View Poll Results: YES or NO to new head studs?
Replace the head studs
51
68.92%
Keep the old ones
23
31.08%
Voters: 74. You may not vote on this poll
My car goes in on the 8th for new cams, cam gears and a new fuel pump. It'll get a fresh reflash and dyno tune later that day. My question is should I replace the head studs at the same time. Please explain why. I've heard some pretty convincing arguments on either side.
Originally Posted by laggin3
Id rather have my head gasket blow rather then buy a new block.
The typical method for doing head studs when your doing a cam install is to swap one stud at a time.. Many of us have found that its important you do the head stud swap properly or you will run into problems. Leaks and possible blown head gaskets due to improper/inconsistent torque.
My suggestion is to keep the stock studs until its "Really necessary" to replace them.
I have not done head studs, and don't intend to do them until I remove the head for whatever reason and need to replace the head gasket..
Ultimately if you run high boost, you'd likely end up pulling the head because of a leak or headgasket problem anyway regardless.. At that point I'd replace the headgasket and studs.. Remember gaskets compress, if you relieve the tension on a bolt, or alter the torque holding it down, the gasket may not compress properly making a good seal.
Some have seen leaks appear after doing head studs...
Just keep that in mind, I felt it wasn't necessary on my car until I pulled the head off.
Originally Posted by smokedmustang
What did I miss? If you use the headstuds, you have a better chance of blowing up your block? I haven't heard that one before. Who did it, and was it attributed to the studs only?? it there a chance of you warping your aluminum head on stock headstuds? I guess I haven't been paying attention on this one. Interesting though.
Didnt say anything about the studs making your car prone to detonate, but with a stock headgasket and stud the weak point is your headgasket. If you experience true knock the headgasket will go. With the higher tensile strength of aftermarket headstuds the weak point becomes the internals. On a complete motor build, of course you should run them, as your internals are more suited to the task of detonation resistance. MalibuJacks explanation was very thorough if you do plan to go this route.
