Devo Tunings Quartermaster Twin Disk
Old Aug 26, 2006 | 11:15 PM
Jim_Patterson's Avatar
Its time for my clutch to be replaced and I have been reading into the various types and brands of clutches. A friend thought I should try out the Quartermaster twin disk that Devo Tuning sells. I searched evom and didn't get alot of results or info on it.
I know this clutch is the better push style, but has anybody ran it or had any expereiences with it?
Any help is appreciated.
Old Aug 27, 2006 | 08:10 AM
TrinaBabe's Avatar
Yes I have used it on my Evo and DSM. It is currently in my car with well over 200 launches slipping it out a decent amount. It makes the car chatter alot and is pretty jerky on daily driving. If you dont mind the jerky take offs and the noise it creates than it will hold up to whatever you put it through. Adam is also a top notch guy.
Old Aug 27, 2006 | 08:32 AM
turbodsm03's Avatar
i have it in my dsm and friends have it in their dsm's...clutch holds fantastic but like trina said it is noisy...it is lighter than even a fidanza act combo...if your looking for a clutch that holds power and disengages beautifully then get a twin disc...if you cant stand noise or the jerkiness leaving from a stop then stick to a single disc with a sprung hub.
FYI Adam used to preload the drivetrain with this clutch in his evo ii and it still held up perfect...
Old Aug 27, 2006 | 09:52 AM
Is it jerky take offs because you cant slip it or what? and how noisy we talking? Anyone got a video?
Old Aug 27, 2006 | 09:59 AM
TrinaBabe's Avatar
It sounds like you dropped a bunch of bolts in your bellhousing every time you push the clutch in.
Yes, the jerky take-offs because it likes to grab hard... its more of an on/off than most "normal" clutches.
It also chirps when you shift and dont rev match well... and it chirps while slipping it out taking off... taking off from a dead stop sorta sounds like a belt squeel I guess.
About it holding to abuse trust me... it will hold up to whatever you want. I have pre-loaded mine, hot lapped it at least 10 times in a row and made plenty of passes. Same clutch is in there doin its thing.
Old Aug 27, 2006 | 10:38 AM
But its definatly driveable on the street?
Old Aug 27, 2006 | 01:07 PM
DWAIST's Avatar
i've made many 129+ mph passes on devo's clutch in my dsm and have never had any problems. it was a bit tricky to get used to when i first installed it! every time the clutch engages it made the same skreeching noise that "trinababe" explained, but not to worry that was perfectly normal. i have to say adam's clutch is the best clutch i have ever owned and when the time comes i will be installing one in my IX.
Old Aug 27, 2006 | 03:51 PM
94AWDcoupe's Avatar
I had one in my mirage. Takes alot of effert to pull smoothly from a stop. And I made a heavy flywheel so it would be easier. Once moving the clutch works well. Most will hate this clutch. Very harsh engagement. The clutch is designed for rally use. Its an on and off switch. It will slip without chatter, but it engages in about 1/2 inch of pedal travel most clutches take 2" to fully engage. I loved the way it shifted and didn't want to loose that so I swithced to a tilton carbon carbon.
Old Aug 27, 2006 | 04:01 PM
EFIxMR's Avatar
how is the carbon to carbon streetability wise, i have one sitting but not sure if i want to run it on my street car.
Old Aug 27, 2006 | 04:14 PM
This thread is about Quartermaster clutch, please keep it on topic.
Old Aug 28, 2006 | 03:48 PM
TrinaBabe's Avatar
I daily drive my car.
I has plenty of passes at well over 125 mph slipping the clutch alot.
Old Aug 28, 2006 | 03:51 PM
Genesis8's Avatar
How much is DevoTuning selling the clutch for?
Old Aug 28, 2006 | 06:03 PM
Well shoot, the push style clutches dont work with 6speed.
BTW the clutch is 1700 from devo.
nikg
Nov 18, 2011 12:26 PM
honey on boost
17
Sep 30, 2011 06:40 PM
Jasil
71
Feb 3, 2009 01:06 PM
coolguyuno1
57
Dec 8, 2008 07:35 AM
evolved83
Sep 5, 2008 03:09 PM
