Datalogging - Timing advance
Old May 7, 2003 | 09:49 AM
ShapeGSX's Avatar
You can't datalog knock via OBDII. You can datalog timing, though, which is almost as good.
Old May 7, 2003 | 12:12 PM
mayhem's Avatar
Great info guys!
Old May 7, 2003 | 02:52 PM
CornerHard's Avatar
Nope, you can't log knock w/ OBDII. Also, the data rate sucks, especially if you're logging multiple variables (as mentioned above).
Even though 2nd gen DSMs are also OBDII, we have a tool called DSMLink (www.dsmlink.com) which changes the way the stock ECU communicates, so that you can log knock and everything else the ECU sees at a high rate of speed. You can also alter timing advance, fuel trims, redline, fuel cut, and much more, which is superior to an S-AFC. The catch is that all this magic is possible only with the 95 ECU, which has an EPROM slot on the circuit board, so you can take out the existing ECU programming chip and replace it with the new.
If you're lucky, someone will figure out a way to do this on the Evo (maybe the Evo 8 has an EPROM, since it's the first in America?). Otherwise, the best option for heavy-duty datalogging is getting a standalone like the AEM EMS. For now getting an S-AFC and OBDII logger is probably your best budget logging/tuning combination, even with its limitations.
Old May 7, 2003 | 03:22 PM
mayhem's Avatar
That's what I figured. Getting EVERYTHING you need to log is only around $300 if you go with a cheapo PDA. Not bad considering the kind of use you could get out of it.
I had heard before about the OBDII connection being able to send only so many frames per seconds of data. So the more sensors you're logging the less accurate it becomes. The timing is what's going to be the most important to me. When logging the timing is it crossed referenced with engine speed to complete the X & Y axis?
Old May 7, 2003 | 03:26 PM
AutoXer's Avatar
I'm not really sure what your asking here. They can be logged simaltaniously(sp), if thats what your asking. I can send you a CSV file when I get home.
Old May 9, 2003 | 12:38 PM
AutoXer's Avatar
Here are a few logs of my Evo 8. Import them into a spreadsheet program and graph them.
Just look at that funky timing....
File Type: zip
Old May 9, 2003 | 07:38 PM
AutoXer's Avatar
You can download the windows software for free to examine the logs. www.autotap.com
I've attached a few AutoTap format logs.
File Type: zip
Old Jul 17, 2003 | 07:48 PM
silverEVO8's Avatar
Originally posted by Incognito
Can somebody explain to me what this is?
Datalogging is recording what the ECU/car is doing, right?
How does this all work?
plugs into ECU, or taps in?
Do I use a laptop, or Palm?
How much is this?
Thanks in advance.
I just ordered a Pocket Logger from http://pocketlogger.com
Looks like it will work for me just fine. It logs to a Palm pilot like my IBM C3 (good for nothing else ). I'm going to start logging data to make sure my SAFC2 is a tool for good and not for evil
Old Jul 18, 2003 | 12:18 PM
992gnt's Avatar
I'm using the Pocketlogger, with good results. I wouldn't go to the track without it. Between that and the e-manage support tool software, I'm pretty well covered for tuning. The only other thing I would want is a wide band.
Old Jul 20, 2003 | 06:15 PM
QuantumEVO's Avatar
I think rpm vs. MAP vs. ign is going to be the most useful for datalogging. MAP is more important than MAF with respect to how it times the spark.
Mark
www.Quantum-Racing.com
Old Jul 21, 2003 | 02:32 AM
AutoXer's Avatar
I don't have MAP as a variable with my AutoTap. Do you guys have it on your pocketloggers?
Old Jul 24, 2003 | 10:32 AM
silverEVO8's Avatar
Re: Datalogging - Timing advance
Originally posted by AutoXer
Has anyone been datalogging? I've done one or two with my AutoTap for Palm and I'm getting some strange stuff.
First off, let it be known that I have not done a lot of logging and I am not skilled yet at reading them. I'm seeing timing advance being pulled on some hard accelerations. I'll do some more runs to see if I can make any sence of it. I'm just curious if anyone else is datalogging?
I got my Pocket Logger today... Can you tell me where to find the OBDII plug? I'd appreciate it.
Thanks
Old Jul 24, 2003 | 11:04 AM
AutoXer's Avatar
Re: Re: Datalogging - Timing advance
Thanks
Its just under the dash above your right shin. You can reach it fron the drivers seat. It faces down.
Good luck, tell us how it goes.
Old Jul 24, 2003 | 11:32 AM
silverEVO8's Avatar
Re: Re: Re: Datalogging - Timing advance
Thanks, I'll see if I can get the thing going ASAP.....
Old Jul 24, 2003 | 03:01 PM
boostedwrx's Avatar
Yea listen to Shape he knows whats up (again, as always)
You can only datalog knock with obd I. With obdII you can log timing advance which is just as important. I only log RPM and Timing Advance with my PocketLogger.
This damn logger has stayed with me forever. Ive cleared various CEL of friends, datalogged several tuner cars, and its been useful to me with my old Eclipse and my 660's/SAFC!!
****ty thing is, I can only get 8 or 9 samples a second even when doing the byte timing and what not...
Hiram6g74
Apr 13, 2017 08:59 PM
RawrImAMonster
Jul 22, 2011 07:30 PM
10isace
13
Dec 21, 2009 06:34 PM
uSmC_08
36
Sep 24, 2007 09:23 PM
Stealth Ag
Aug 8, 2006 03:46 PM
