Evo 9 clutch question
Old Aug 30, 2006 | 05:16 PM
D Block's Avatar
Has anyone replaced their clutch on their evo 9 yet? If you did what brand did yall use? Im running a a turbo back exhaust, bov, drop in filter and a flash. Someone reccomeded using a twin disc what do you guys think?
Old Aug 30, 2006 | 05:21 PM
boostedwrx's Avatar
The stock one is good dude. It should be fine with those mods. Unless your getting a turbo kit, id stick with the stocker.
Old Aug 30, 2006 | 05:22 PM
Quickshifter's Avatar
When I had my Evo 8 I upgraded the clutch twice. First I went with an ACT setup which made a lot of noise and was too stiff. After breaking my t-case, I decided to go with a Road Race Engineering X-Clutch...(its their no name brand clutch and its very factory looking as well as sound and feel.) I also upgraded the flywheel but I cant remember the name....If you can get away without the flywheel I would reccomend that....cuz upgraded ones make noise too. Its all on how you prefer your evo. With your modification you definately dont need twin disc.....If I were you I would just check out the RRE X-clutch....low noise, low cost, and good drivability. Plus those guys know whatsup for sure.
Hope that helped.
P.s. How many miles on your 9? Mine is still stock with 16k and no signs of slip...is urs slippin or u just upgrading for the heck?
Old Aug 30, 2006 | 05:25 PM
Turbo Kyle's Avatar
If you take out the restrictor in the clutch line you can make the clutch last longer. Its gives you more control of the clutch.
Old Aug 30, 2006 | 05:29 PM
D Block's Avatar
clutch
Im replacing the stock one cause mine went already. But i was thinking of a twin disc just for the future when i do more modds.
Old Aug 30, 2006 | 05:30 PM
boostedwrx's Avatar
Or just keep the restrictor in and let the clutch out faster.
Old Aug 30, 2006 | 05:32 PM
D Block's Avatar
So is there any other brands that yall recomend
Old Aug 31, 2006 | 07:26 AM
Turbo Kyle's Avatar
I can almost drop the clutch on my new IX and it will still slip a good amout. This is off of the factory 5K launch control.
Old Aug 31, 2006 | 07:46 AM
RobDogg's Avatar
I have a brand new exedy stg 1 w/ flywheel if you want to buy it cheap
Old Aug 31, 2006 | 07:50 AM
jamevo8's Avatar
I have had a ams stage 3 kit on since 1k and now have 27k my clutch is fine (for now)
Tyiler
Jan 9, 2016 11:07 AM
evane
68
Nov 28, 2008 08:57 AM
blackdemon
Mar 16, 2008 05:05 AM
redevo21
Dec 18, 2007 10:59 PM
1BlackEvo9
Nov 4, 2006 01:06 PM
