GT35 ... Antisurge Housing? Questions
Old Oct 24, 2006 | 11:11 AM
  #31
AlwaysinBoost's Avatar
maybe I'll use this as an excuse for putting the cams in... but not until after one more track day of running mid 11s!
what are your cam gear settings again if you don't mind me asking? I don't have gears but would you suggest them?
Old Oct 24, 2006 | 12:24 PM
  #32
Ted B's Avatar
I'm using 0/-2, and that setting is working very well. I suspect it would work well for you also, but even 0/0 is going to be much better than what you've got now.
Old Oct 24, 2006 | 08:58 PM
  #33
homemade wrx's Avatar
Originally Posted by EVOlutionary
Would this scenario be compressor surge?
Go full throttle at 4000 rpms, boost comes up to 28psi (20G9 turbo), let off the gas to about 50%-75%, boost falls down to about 2psi, then you roll back on the gas. As you roll on the throttle you get a very fast da-da-da-da-da "machine gun" noise, the whole car shudders and the BOV opens and closes very rapidly. I can not log in the EMS any abnormalities when this happens - logs look completely normal. This was not able to be tuned out or around with any features of the AEM EMS.
Does that sound like surge?
EVOlutionary
sounds like surge to me from what is happening although I really don't know what the compressor map for that turbo looks like...compressor map is an easy way to find out for certain if you can't data log.
I think it is probably just bov flutter though.
in response to another post, how would not having surge ports make the spool up quicker?...I would have guessed the opposite, having never seen data of one vs. the other
Old Oct 26, 2006 | 06:29 AM
  #34
SophieSleeps's Avatar
How can you be certain by looking at a compressor map unless you had your head flow tested?
Old Oct 26, 2006 | 10:16 PM
  #35
well you will need some data logging(boost) and a few ballparked assumptions (VE being one of them)...you can see with the boost pressure and airflow (mass or volumetric) where you fall on the compressor map...if you are past the surge line, well...I would assume he's surging.
Old Oct 26, 2006 | 10:35 PM
  #36
I think that one's volumetric efficiency is quite a big factor to assume.
It's like having a graph of X and Y...and you're guessing the Y values and then making judgements on it.
Old Oct 27, 2006 | 02:27 PM
  #37
yes, but it can be calculated (hence ballparked) from given values of the car, such as hp/tq at a given rpm with numerous other variables...such as air temp, boost pressure (need a compressor map for air flow at temp), air fuel ratio, etc...
Old Nov 4, 2006 | 02:04 AM
  #38
trinydex's Avatar
why didn't you search first?
there are many types of surging. a turbine based surge is whent eh turbine is the bottleneck and the overall engine delta moves towards unity to the point that there is a resistnace in the acceptance of more mass flow. this is not common but can be produced with bad compressor to turbine matching. basically compressor is too big for turbine, can't cram anymore air in choke choke buck buck is what you feel. so putting a 35r wheel on a stock turbine would do this.
the other type of surge is what the compressor housing is machined for. it's when the housing moves TOO MUCH AIR and the fins of the compressor blade stall. this stalling causes a momentary free floating of the wheel, what i mean by free floating is that the wheel is moving under almost no friction, it moved so fast that the air cannot grip onto it and that being the case it moves without viscous effect (kind of) this of course only happens for a fraction of a second after which the air grabs the wheel and gives everything a nice yank. this is bad.
the housing is machined such that there is a reduction in pressure gradient going into the compressor inlet. those holes fill up with air and fire it backwards, this makes sure that the air is never moving too fast as it comes into the compressor. does this reduce mass flow... it rather babysits mass flow... it makes sure your mass flow stays intact with the compressor so it can continue to flow, otherwise it's just mass... no flow.
if you understand this coarse definition then you'll see that ONLY large compressors will have antisurge housings. there is no need for small turbines to have such a device because for one cannot move fast enough and two will never flow enough. the flow enough part i'm fudging because the flow doesn't dictate the compressor wheel speed, but let's say you'll never come to a case where the flow will seperate from the wheel when the wheel is small. why? because the smaller the wheel the smaller the radius of the wheel this means that the speed of the tip of the blades is slower than a bigger wheel going at the same rpm.
just about all turbos go the same speed... flippin' fast. so small radius wheels don't have high tip speeds, but big wheels do. so you'll see the flow seperate from the big wheels and that's bad.
Old Nov 4, 2006 | 08:21 AM
  #39
turbo's have a large variance on speed...generally the smaller the faster they turn and small turbines can have surge as well, it is dependant on both housing with respect to the size of the engine (and exhust temps capable i.e. rotary).
evo4nr
Mar 21, 2011 04:32 PM
R/TErnie
35
Jun 1, 2010 07:25 PM
Evo8Emperor
Oct 11, 2007 11:59 AM
blackonblackevo
10
Jul 7, 2007 05:23 PM
TrinaBabe
Apr 3, 2005 05:48 PM
