Intake manifold explosion! Alcohol possible cause?
Old Nov 17, 2006 | 08:19 PM
  #61
Magnus's Avatar
Originally Posted by nutrulz
Recently had a meth backfire, and it destroyed my IAC. What can be done to prevent meth backfires?
MSD and NX sell a window switch that uses pills from their ignition box to set your RPM limits. FJO has a PC programmable setup http://www.fjoracing.com/products/waterinjection/
or you can set parameters in your EMS if you are using one.
You should also avoid bouncing off the rev limiter at all costs as there really is no way to protect you when your on the rev limit.
It must be treated much like Nitrous Oxide, only difference is shuting off your methanol injection a few hundred RPM too early before your rev limit; like some do with nitrous; can be catastrophic as well.
Be aware of your engine RPM, and if you cant hack that, us old schoolers just prefer straight C16, and no meth injection.
Old Nov 28, 2006 | 08:49 PM
  #62
DSMFRK's Avatar
this happend to my friend to who was running alky injection on his magnus manifold. on 25psi on a DSM. And his was only 2 months old.
Old Nov 28, 2006 | 09:12 PM
  #63
marksae's Avatar
Time to put a pop-off valve on the intake.
Old Nov 30, 2006 | 08:14 AM
  #64
Fourdoor's Avatar
Actually if they make pop off's with enough capacity that is actually a damn good idea. Get a pop off with a pressure rating of 50 psi and it should prevent manifold explosion in the event of a backfire, but not leak under normal boost pressure. Hell, a simple "blow out" diaphrame style would work fine.
Keith
PS: If we can't find an actuall pop off valve, a BOV without any vacuum lines attached and the correct spring pressure may be useable.... not sure about that though.
Old Nov 30, 2006 | 10:39 AM
  #65
4G93Turbo's Avatar
What about using a product like the B*ee R Rev Limiter which pulls timing at a adjustable RPM instead of letting the stock Rev Limiter pull fuel........ ? (by "pulll" I mean shutoff)
Old Nov 30, 2006 | 10:50 AM
  #66
nutrulz's Avatar
So this is obviously a problem, not necessaryily with the Magnus, but with inappropriate timing. So, how can we avoid this?
Old Nov 30, 2006 | 10:57 AM
  #67
EVOMIZ's Avatar
Damn Son
Old Nov 30, 2006 | 11:14 AM
  #68
HPF Kyle's Avatar
running meth or nitrous? sounds like a good investment to me.
Old Dec 1, 2006 | 09:20 PM
  #69
brobards's Avatar
+1
I can vouch for these, I have seen them save a couple engines when a backfire occurs.
Old Dec 7, 2006 | 04:56 PM
  #70
ShaunSG's Avatar
Originally Posted by Ted B
the mixture in the manifold is explosive, and is subject to ignition if something causes a sparkplug to fire at the wrong time (i.e. while the intake valve is open).
As others have said, it is rich misfire, not sparking with with intake valve open. How would that even happen with the car running fine before? Spark timing that far off would cripple from the start.
Old Dec 7, 2006 | 05:05 PM
  #71
SlowCar's Avatar
why is it that this kind of explosion is not seen (or maybe not reported) in cast type intake mani like the stock ones?
the sheet metal intake mani has lots of volume for methanol to pool......
Old Dec 7, 2006 | 05:17 PM
  #72
DRFTKNGG's Avatar
Same reason the top fuelers run the burst pannels on the blowers....
Old Dec 10, 2006 | 10:16 AM
  #73
ExViTermini's Avatar
This is an interesting thread to me...as I just had my motor blow friday nite. I too am running 30psi on a meth injected hp61. My fpr vaccuum line had been blown off at some point during the explosion.
I was awfully close to the rev limiter, and the stock tach does begin to lie as it cannot keep up with the engines revs once you get around the 450-500whp+ mark. I'm still trying to figure out exactly what happened and it seems something along these lines could be a feasible possibility.
Sapik
Dec 20, 2008 10:48 PM
oguratevo
May 18, 2007 09:20 PM
vegasboy301
Dec 12, 2005 06:30 AM
Titaztik
Aug 30, 2005 04:45 PM
DiamondWhite
15
May 1, 2005 06:41 AM
