Cam install please help.....
Old Sep 10, 2006 | 09:38 PM
RevMoto's Avatar
I am putting my valve cover back on and I know it is 31 inch-lbs but I only see foot-lbs on my torque wrench. I put it to the lowest setting first and i started to tighten and heard a pop. Check everything and no cracks. WTF.
Old Sep 10, 2006 | 09:40 PM
Compjoc's Avatar
31 inch-lbs = 2.5 ft-lbs.
Does your torque wrench go down to 2.5 ft-lbs (most ft-lb wrenches don't)?
Your probably over tightening it.
Old Sep 10, 2006 | 09:42 PM
RevMoto's Avatar
OMG I went way over. That pop must have been a crack but I do not see any cracks. What should I use then?
Old Sep 10, 2006 | 09:48 PM
mchuang's Avatar
If no crack it should be fine. I know the manual says torque the valvecover, but I never have torqued the valve cover any car I have ever had. It has a gasket so it should be fine with moderate force behind the ratchet. Just dont go hercules on the ratchet.
Old Sep 10, 2006 | 09:49 PM
Compjoc's Avatar
Before retightening all the bolts, you should pull the valve cover back off and check for any bending and/or cracking. Make sure its good and flat to allow for a nice seal.
Old Sep 10, 2006 | 10:00 PM
kf6ytc's Avatar
Your hands, it's not that critical that you need a torque wrench, just tighten it until it's tight, if u cannot feel out how tight it should be using a 1/4 drive socket wrench, you probably should have not done the install in the first place.
I would take the car to a mechanic and have him recheck your install and finish it........... If you made one small error = BOOM, you don't sound nearly competent to be doing a cam install if your asking a simple question like you did above.
TJ
Old Sep 10, 2006 | 10:04 PM
EV0lut10n_8's Avatar
Or you could just buy a torque wrench that has inch pounds and do it right for peice of mind.
Old Sep 10, 2006 | 11:31 PM
RevMoto's Avatar
I will just do it by feeling it. I cannot find a torque wrench that goes that low.
cbr1000
64
Aug 4, 2012 06:51 PM
travail
Jun 25, 2009 05:35 AM
whitersevo
32
May 31, 2007 08:39 AM
spyderx
33
Feb 3, 2007 04:48 PM
DaiMos
Dec 12, 2005 04:17 PM
