Methanol's affect on AFR readings
Old Sep 13, 2006 | 04:16 PM
Fourdoor's Avatar
OK, laymens terms for everyone!
An O2 sensor does NOT read your A/F ratio, it reads the O2 content of your exhaust gases.... this value is known as "lamda". To display your A/F ratio rather than the actual lamda value the wide band O2 sensor control unit does some simple calculations based on what fuel it is designed for, or in some cases what fuel the user has selected the gauge to be calibrated for.
If the control unit is set up for Gasoline, and you run E-85 (85% ethanol) the wide band would still display what would be a "normal" value for gasoline at that O2 content in the exhaust gases. If the gauge reads 11:1 at WOT you are running fat, if it reads 15:1 at WOT you are dangerously lean..... just like normal.
Keith
Old Sep 13, 2006 | 05:10 PM
smokedmustang's Avatar
Keith
I can take my Dunce-cap off now, I understand! Thanks again Keith, you don't make me feel retarted anymore!
Old Sep 13, 2006 | 06:54 PM
dubbleugly01's Avatar
it's retarded, dork
just funnin with you Dr. Smoked.
Old Sep 14, 2006 | 09:48 PM
dudical26's Avatar
If you have a wideband that allows you to input the stoich value of the fuel you are using, would inputting something a little lower than 14.7 help to offset the effects of meth on your AFR. For example if I entered 14.2 would that make it so that my AFR was accurate when the meth was spraying?
Old Sep 14, 2006 | 11:27 PM
Fourdoor's Avatar
For the love of GOD!!!!!!!!!
It is correct NOW. If you jack with the input, you will have to re-learn what values corrolate to rich and lean with the new value you have put in.
Yes, you can program it so that 6:1 is stoich (value for pure methonal) if you want. Do you know what A/F ratio would be way rich for meth? Do you know what A/F ratio would be dangerously lean for meth? I don't.
You could program it for E-85 (around 10:1 stoich) and once again have no clue what would be too rich or too lean.
You could program it for Pure ethonal (9:1 stoich) and (you guessed it) once again have no clue what values corrolate to too rich or too lean.
Or you can just leave it the F alone, and know that 14.7:1 is stoich, 10:1 is rich, and 13:1 is lean.
Keith
Old Sep 25, 2006 | 02:04 AM
SlowCar's Avatar
Keith
lol!
Old Sep 25, 2006 | 02:52 AM
Originally Posted by dubbleugly01
it's retarded, dork
I just saw this, always mispell that............. What is Stoich? wasn't he a kicker for the Dolphins?
Old Sep 25, 2006 | 03:15 AM
I guess "stoich" is perfect mixture?http://en.wikipedia.org/wiki/Air_to_fuel_ratio
I am looking too deep in this I guess.
esevo
43
May 31, 2015 05:55 AM
Anarchy99
13
Jan 20, 2012 12:52 PM
maperformance
Sep 7, 2010 01:39 PM
Ultimate CC
Jun 1, 2006 05:59 PM
BJai02
23
Jan 29, 2006 10:07 AM
