So close...
Old May 28, 2006 | 06:06 PM
Ultimate CC's Avatar
So close...
Went to Island Drag Way today and started doing some tuning on 75% methanol and started off with a 1.654 12.926 110.24 and within 3 more passes got it down to a 1.670 12.040 114.44 and the only changes I made were tuning the afr's. This map started off as my 50% map with conservative timing. Once I get the afr's dialed in as they are about 11.2-10.8 right now and start uping the timing I should be able to finally hit 11s.
Old May 28, 2006 | 06:59 PM
blue by ray's Avatar
Also went to the dragway today, first time racing and best time was a 1.848 60' and a 13.53 1/4 mile. Trap speed was only 97.52 though. Seems a little low no?
Mods are injen intake, hallman mbc, and tuned for 22psi.
Old May 28, 2006 | 07:26 PM
Warrtalon's Avatar
UCC, good job. Be careful with going that lean on meth unless you have a failsafe built-in with the UTEC (guessing you do).
Ray, yeah, that is incredibly slow. That's about 3-5mph slower than stock. Normally, I'd point to the Injen, but you said you're tuned, so all the mods in your sig should be working well for about 110mph traps on 93oct.
Old May 28, 2006 | 07:52 PM
C6C6CH3vo's Avatar
Ultimate CC is Mr. Safety
Good run!
Old May 28, 2006 | 08:16 PM
awdmofo's Avatar
I'd like to see the timeslip of that '1.654 12.926 110.24' pass. Should be at least mid 12 with that 60ft and trap speed unless you missed a shift or something.
Old May 28, 2006 | 08:20 PM
Warrtalon's Avatar
He had to have missed a shift. That would normally be a 12.2 at that mph unless his shifting is slow - the 12.04 @ 114+ indicates a little shifting tardiness but nothing bad.
Old May 28, 2006 | 11:29 PM
silverofs's Avatar
you think he is tardy on shifts try running 12.0's @ 120 with 1.8 60fts
good run ultimate cc you will get there
Old May 29, 2006 | 12:15 AM
The 12.9 was from the UTEC pulling massive timing in second gear due to some knock caused by the really rich condition. I have it pull massive timing for any knock above a 3 count as an additional failsafe on top of the safeinjection. My shifting has certainly improved from the last couple outings, finally was able to pull a 4.9 330' which was what I believe was keeping me from 11s on my 50% meth mix. I will be tuning the 75% to afr's of 11.6-11.3 which is pretty safe by most standards. The one thing I am really impressed with this car is how well stock clutch is holding. The car now has about 60+ passes at the track this spring and still has plenty of life left in it. This drag racing gets so addicting, I will be going back this sunday I believe...
Old May 29, 2006 | 10:00 AM
C6C6CH3vo's Avatar
Originally Posted by Ultimate CC
knock caused by the really rich condition. .
I didn't know that happens, Im probably knocking like mad being untuned - overrich
how well stock clutch is holding. The car now has about 60+ passes at the track this spring and still has plenty of life left in it. .
Looks like if the mitsu clutch holds well originally it's good to go for the long haul - must be the break in or something
Old Jun 1, 2006 | 05:59 PM
I ran the car without the catback...haven't put it on yet. But the car was tuned for an intake and boost.
lancerrally45
May 31, 2016 11:09 AM
EvoIXPilot
Apr 12, 2013 09:56 AM
NOMIEZVR4
Oct 17, 2011 02:09 PM
LaXGSR
13
Jun 13, 2009 11:12 PM
EE
Aug 19, 2008 09:10 PM
