At what point is a HKS DLI 2 needed?
Old Sep 14, 2006 | 09:26 PM
EVORSPWR's Avatar
I am trying to make a 400 to 450 WHP car here. Maybe the Buschur 20G or GT3071 setup. A car with hopefully a good powerband. Is this ignition box needed when running 2 heat range colder plugs? Or is it more of a ignition failsafe? If there is such an animal. Thanks for any help.
Old Sep 14, 2006 | 09:35 PM
Cirrusly Evolvd's Avatar
I asked AMS if they recommended one with my 50 trim (450hp) and they said no I didn't need it. Hope that helps ya.
Old Sep 14, 2006 | 09:38 PM
EVORSPWR's Avatar
I guess AMS doesn't put the HKS DLI2 on there for a reason?
Old Sep 14, 2006 | 09:48 PM
tripperfx3's Avatar
Basically your ignition produces an incredible amount of power (voltage) and unless you've got a dedicated drag car making 1000hp plus its not really needed. If you dont believe me take a spark plug out and crank your car and touch it and see what happens... lol Please dont really do it....
Old Sep 14, 2006 | 10:13 PM
joeracer321's Avatar
I find that the DLI-II makes for a much smoother idle on cars with cams or injectors. It not only increases spark energy but it is a CDI, so it give a multiple spark discharge. I have one on my Evo and have been very pleased with it. I hope that helps!
Old Sep 15, 2006 | 05:58 AM
SlowCar's Avatar
whats CDI?
Old Sep 15, 2006 | 06:13 AM
Smogrunner's Avatar
I'm running a completely stock ignition system, including stock heat range plugs.
Old Sep 15, 2006 | 06:16 AM
jbrown's Avatar
The DLI helped smooth out my car a lot at WOT and I only make about 325whp (Mustang dyno)
Old Sep 15, 2006 | 06:27 AM
4Gsixty3's Avatar
make idle smoother and quicker response, not really needed but its not useless either.
Old Sep 15, 2006 | 06:58 AM
AlwaysinBoost's Avatar
thats good to hear... but are you sure your not pre-ignighting at all???
Old Sep 15, 2006 | 06:59 AM
mikesevo8's Avatar
Originally Posted by SlowCar
whats CDI?
I believe Capacitive Discharge Ignition.
I just put a DLI on my car. I believe it helped at high RPMs at the track.
I hit my highest trap speed to date. The car didn't feel as if it fell off as much at the top end.
Also, and I can't say for sure if it's related, but after I installed it, I took a trip (me and the GF went to Six Flags)
and I got over 350 mi on that tank of gas. I usually get 300-320 for that kind of highway driving.
Old Sep 15, 2006 | 07:36 AM
Inn-Tune's Avatar
For what it's worth when we ran over 25 psi we got ignition break up on the 50 trim. This was with AEM EMS, stock plug wires, and one heat range colder than stock NGK plugs gapped at .024". With the ignition box and no other changes it ran 32 psi no problem. Perhaps AMS knows something about your setup that I don't...like that you're running upgraded wires or a difference management system etc.
Adding a DLI II certainly can't hurt as long as you install it properly, so if you're unsure you can wait until the car misfires or you can play it safe and add it in advance. Personally I like to take care of something as potentially dangerous as full load misfires up front.
-Mike
Old Sep 15, 2006 | 07:43 AM
Paul Nelson's Avatar
i missed at 32lbs of boost with 500whp in 4th gear at the track...i gaped my plugs to 15 just to get rid of the miss.
i went with the hks dli 2 and have no miss with a gap of 24
Old Sep 15, 2006 | 08:00 AM
what was the difference in MPH between .015 with stock ignition & .024 with the DLI?
Old Sep 15, 2006 | 08:05 AM
KazzEvo8's Avatar
Are you all just integrating the DLI II to your stock ignition harness or using a COP? If so, who's parts? And who's got good deals on the HKS DLI II?
Thanks.
