GT35R + stock block *help*
Old Sep 27, 2006 | 10:22 AM
topsecret's Avatar
Hey guys..
I tried searching but none came up with someone using a standard block for the GT35R.
I've got Tomei 280s, Tomei Valve springs, Tomei cam pulleys, Tomei 1.2mm MG, etc.
Basically normal bolt on parts and a done up head with AEM ems.
Running standard internals for now, lack of $$$
Planning to get a GT35R with a 0.63 a/r.
Car is a DD but will see the drag strip from time to time.
1. At what rpm would the GT35R start to come on ?
2. At what rpm would it achieve 18-20psi ? (100 octane)
*thanks in advance*
Old Sep 27, 2006 | 10:39 AM
WrX Kila's Avatar
Get your flame suit ready. Normally a 35r will see full boost anywhere from 4900-5500 rpm. 20psi is too low for a 35r, you will need to crank it up at least to 25psi to see its potential. Make sure your head bolts are upgraded. 410whp - 440whp at a minimum.
Old Sep 27, 2006 | 11:04 AM
h.funk's Avatar
Dont know why he would need a flame suit. Seems like a perfectly lagit question.
Old Sep 27, 2006 | 11:07 AM
sonicnofadz's Avatar
In my opinion, I would rather run 272's to reduce some of the lag (more mid range torque). Good luck on your project, hope you have a spare car
Old Sep 27, 2006 | 11:08 AM
DreamLike1's Avatar
I know you've already said that you are getting a GT35r but why not consider a 50 trim turbo?
If you're sticking with stock internals, this is really the turbo to get. Capable of 400+ whp with much less lag than a GT35r. Plus it has potential to push into 500whp range with race gas (and here is where built internals would be a good idea).
just a suggestion it would make for one hell of a DD
Old Sep 27, 2006 | 11:14 AM
locam's Avatar
I have HKS 264in/272exhaust combo, and I hit full boost between 4600-4700rom. Pump gas psi is 24.5. Made 435whp at that boost level.
caelin~
Old Sep 27, 2006 | 12:29 PM
Bdub25's Avatar
You may have a little more lag due to your cams being so big. And if i were you i'd run more boost than 20lbs. I'm having meth installed and i'll be running 33lbs.
Old Sep 27, 2006 | 01:15 PM
Invoice EVO's Avatar
Veteran: Air Force
Originally Posted by topsecret
Hey guys..
*thanks in advance*
I don't think you looked hard enough.
Old Sep 27, 2006 | 01:53 PM
sleet's Avatar
35R spooling at 4900-5500? Where the hell do you get your information from? Most people can spool 42R's before those numbers.
Old Sep 27, 2006 | 02:32 PM
WrX Kila's Avatar
READING IS FUNDAMENTAL!!!!! FULL BOOST NOT SPOOL CORKY!!
Old Sep 27, 2006 | 05:28 PM
AlwaysinBoost's Avatar
I will be reinstalling my 35r this weekend. I have a map sensor hooked up so I'll be able to log RPM and boost to give you an accurate real life idea of what spool up will be like on the street. Although I believe this information has been posted many times before... you need to search for it though.
Old Sep 27, 2006 | 06:32 PM
topsecret's Avatar
so i should use Procams 270s instead to minimise lag ?
most of the ppl using GT35R here are using the one with the 0.82 a/r right ?
i'll be getting the 0.63 a/r one from Garrett itself.
the problem is I think I'll go for a stroker only sometime next year.
So i have to stick to the stock block for now,
dont mind getting a bigger turbo now rather than buy a different turbo again.
cheers..
Old Sep 27, 2006 | 06:42 PM
Spooldyou's Avatar
Hey guys..
*thanks in advance*
Well i will be running a 35r with Comp 280s to start, see if they make any good power. mine will spool alittle later, but thats ok, I dont mind
I dont think you did a good search, I have a thread right now of Stock block stock ECU with all the bolt ons, here the link
SpooldYou's GT35r build up!
Old Sep 27, 2006 | 06:54 PM
denolloyd's Avatar
Before my 2.3, I ran my 35r on the stock block with all the mods listed in my sig. I saw full boost (32psi) at 5000ish. Imo, the 35r needs to be ran at 28psi or higher in order to be effective. this is not a pump gas friendly turbo (unless u run meth as I do). Hope this helps.
Old Sep 27, 2006 | 07:21 PM
topsecret's Avatar
thanks for that link, Spooldyou. All the best for your project.
denolloyd,
atleast 28 psi ? damn. thats a lot of boost for the stock motor.
what a/r is your GT35r ? what was the compression of your motor ?
