leak down test just tested?
Old Sep 27, 2006 | 01:01 PM
evoal83's Avatar
i just did a leak down test everything was fine except the blow off valve i had the boost up to 15 pounds.there was a leak from the valve.my question is should there be no air coming out at all?even when i have the car on ideling you can feel very little air.also wondering does this hurt my performance considering i'm running 21 psi. thanks.also the valve is a cheap ebay monza wanna be hks ssqz.the person before me had it on there.should i just buy new blow off valve?
albert
Old Sep 27, 2006 | 01:24 PM
05evoGSR's Avatar
leak tested mine up to 22psi and my greddy didnt leak at all...def get rid of that piece of crap BOV. The stock one will serve you much better.
Old Sep 27, 2006 | 01:28 PM
upstateEVO's Avatar
I just did a boost leak test this weekend. I have a stock DV valve and it began to leak at 8psi and got worse up to 20psi!!!
I just ordered an MR DV valve. Best deal I found was 109 shipped from gruppe-s.
Old Sep 27, 2006 | 01:40 PM
EvO6-RS2's Avatar
MR BOV waste if you plan to turn up the boost or upgrade your turbo...buy a Tial or Greddy. My Friend used one a MR with his GT35r and it kept opening under pressure.
Old Sep 27, 2006 | 02:39 PM
gsrboi80's Avatar
Running the boost level in your sig the JDM MR or IX BOV will be your best friend up to about 25lbs. Forge makes a DV that will hold more if needed
Old Sep 27, 2006 | 02:42 PM
05evoGSR's Avatar
If you can find a greddy type-S i would say (and many others) thats the best BOV for our cars. You do the single spring mod and its acts basically just like stock but will hold whatever boost you put to it. Not to mention sounds really nice with an intake on. I think i got mine from EvoMoto for $210 shipped over a year ago. They have discontunued the Type-S but you should still be able to find them around.
SILVER SURFER
241
May 5, 2011 07:25 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
ddubdb3
17
Nov 21, 2006 03:58 PM
