Need Help Flooded Engine!!! Engine seized??
Old Sep 30, 2006 | 09:48 AM
  #31
CO_VR4's Avatar
For those who don't recognize the obvious, when you pull the plugs and turn over motor, if you have liquid in the cylinder you WILL have it forced out of the spark plug holes under high pressure, and it will make a huge mess in your engine compartment (or in your eye, if you're looking down there...).
You would be well advised to change the oil in your motor as well, as any meth that was in the cylinders and made it past your rings is now in your oil.
Hope you didn't bend a rod. If the combustion chamber was full of incompressable liquid and the motor turned all the way over with the plugs in and the liquid in the cylinders, something had to give...
Old Sep 30, 2006 | 10:00 AM
  #32
whitersevo's Avatar
wow all he really did was flooded the engine with meth... so much liquid in the cylinders that a spark cant lite it.. just pulling the plugs. and letting it sit will do the job.
Old Oct 1, 2006 | 12:25 AM
  #33
liquidlancer's Avatar
oh and because noone pointed out the obviouse you shodunt really be touching the stuff or in als case dumping it on your head lol
Appearance: clear, colorless. Flash Point: 11 deg C. Poison! Cannot be made non-poisonous. Causes eye and skin irritation. May be absorbed through intact skin. This substance has caused adverse reproductive and fetal effects in animals. Danger! Flammable liquid and vapor. Harmful if inhaled. May be fatal or cause blindness if swallowed. May cause central nervous system depression. May cause digestive tract irritation with nausea, vomiting, and diarrhea. Causes respiratory tract irritation. May cause liver, kidney and heart damage.
Target Organs: Kidneys, heart, central nervous system, liver, eyes.
Potential Health Effects
Eye: Produces irritation, characterized by a burning sensation, redness, tearing, inflammation, and possible corneal injury. May cause painful sensitization to light.
Skin: Causes moderate skin irritation. May be absorbed through the skin in harmful amounts. Prolonged and/or repeated contact may cause defatting of the skin and dermatitis.
Ingestion: May be fatal or cause blindness if swallowed. May cause gastrointestinal irritation with nausea, vomiting and diarrhea. May cause systemic toxicity with acidosis. May cause central nervous system depression, characterized by excitement, followed by headache, dizziness, drowsiness, and nausea. Advanced stages may cause collapse, unconsciousness, coma and possible death due to respiratory failure. May cause cardiopulmonary system effects.
Inhalation: Harmful if inhaled. May cause adverse central nervous system effects including headache, convulsions, and possible death. May cause visual impairment and possible permanent blindness. Causes irritation of the mucous membrane.
Chronic: Prolonged or repeated skin contact may cause dermatitis. Chronic inhalation and ingestion may cause effects similar to those of acute inhalation and ingestion. Chronic exposure may cause reproductive disorders and teratogenic effects. Laboratory experiments have resulted in mutagenic effects. Prolonged exposure may cause liver, kidney, and heart damage.
Old Oct 1, 2006 | 05:28 AM
  #34
Creamo3's Avatar
Yes definately be careful w/ methanol; not only is bad for you but also flammable. I also changed my oil and did some fresh plugs afterward. Everything is good now and I even fixed the couple of boost leaks I was orginally testing for
jnp1993
Mar 18, 2017 01:16 PM
RyanD3
Lancer Troubleshooting
Nov 12, 2016 01:14 PM
sunnyt87
18
Sep 5, 2012 09:34 AM
armysoldier1073
12
Jan 14, 2012 10:23 PM
billevo1x
15
Oct 4, 2009 05:01 AM
