Crower 272 Cams Help
Old Oct 3, 2006 | 07:51 PM
xLaNcErEvOx's Avatar
Question Crower 272 Cams Help
So I finally decided to go with the affordable Crower 272/272 camshafts. I just needed some advice on what to do after/during the install. What other parts should I buy (ie. headstuds, cam gears...)? Can I tune with an SAFC2 for some gains and drivability (i know i cant control timing)? And last, is there anything I need to know when I get someone to install the cams (special instructions, degree)? Thanks.
Old Oct 3, 2006 | 08:01 PM
joseph143's Avatar
its just my opinion but since your alreay going to be tearing your head apart that you should upgrade the head gasket and studs at the same time... since chance are your eventually going to go with other performance mods its a good step to get ahead of the curve. Cam degreeing depends on how mean you want your car to be and on the cam profile your using. rather then going with safc2 you should look into a dyno'd reflash or a mail in type reflash... they will be better for you car and you wont have the chance of a dumb friend playing with the settings when the drive your car... happen to my civic. but like i said its just my opinion
Old Oct 4, 2006 | 01:12 AM
mchuang's Avatar
First off throw the afc as far as you can, and buy a tactrix cable, then download ecuflash afters install cams and tune with a free logger or buy evoscan
Old Oct 4, 2006 | 03:02 AM
Jax419's Avatar
^^^ +2...I sold my AFC a month ago!
Old Oct 4, 2006 | 04:13 AM
Ang Wen Yan's Avatar
+100000!!ECUFlash FTW!!
Old Oct 4, 2006 | 06:27 AM
Paul Nelson's Avatar
stay with the stock head gasket
Old Oct 4, 2006 | 06:53 AM
CO_VR4's Avatar
Installing cams does not require that you remove the head from the block. It's a simple procedure (comparatively speaking), and requires that you either remove and reinstall the timing belt, the valve cover, the cam caps, the stock cams, and then install the aftermarket cams and put it back together. You do not need to disturb the head studs or the head gasket.
Why would you take off the head if you don't have a problem with a head gasket, unless you're planning to run huge boost and/or RPM? If you are, you'd want to use higher grade head studs (ARP or those offered by AMS/Titan), forged pistons and rods, and upgraded rod bolts, for example.
Old Oct 4, 2006 | 07:14 AM
cfdfireman1's Avatar
http://www.evomoto.com/tech_info.php...3_6&tech_id=18
And make sure you bleed the lifters it's not included in this guide but it should be done. While the valve cover is off it wouldn't be a bad idea to add the ARP studs since you know you'll be doing more mods in the future.
corbzin
Jun 12, 2012 08:28 PM
williams12
Sep 11, 2008 04:42 PM
BallinAssRSvIII
Jun 19, 2008 12:40 PM
Hitman_99
Apr 6, 2008 02:18 AM
nikkadanny
31
Dec 27, 2007 02:03 PM
