Syncromesh in Transfer Case
Old Oct 5, 2006 | 02:27 PM
chase123's Avatar
So I got a clutch install, and the shop told me they put in the right fluids. 200 miles later I get the howl. I ask them what fluids they used, and they said Synchromesh with TX-7.
I stopped driving the car immediately until I got Diaqueen LSD fluid but the noise is still there. The shop tells me I am barking up the wrong tree when I questioned their choice of oils.
Bring it to the dealership, and hope for the best?
Old Oct 5, 2006 | 02:30 PM
mrcox's Avatar
You need a gear oil in the trancfer case. Not synchromesh. It is what caused your whine. I hate to say it but it caused your ring and pinion to wear causing the whine.
Old Oct 5, 2006 | 02:32 PM
DaWorstPlaya's Avatar
Ouch your TC is toast ... you should use either the stock fluid or an exact equivalent. Sychromesh should only be used in the tranny and never the TC .... the shop might owe you a new TC ...
Old Oct 5, 2006 | 02:33 PM
Tristar's Avatar
Ask the shop if the better business bureau would be barking up the wrong tree if they questioned it. I CANNOT stand shops who try and intimidate customers...
EVIL_EVO_VIII's Avatar
Youre done!! Your gona need a rebuild.. Send it to Shep or TRE
Old Oct 5, 2006 | 02:35 PM
joeymia's Avatar
wow syncromesh is way to thin for your tcase. Were there a bunch of metal shavings when you replaced the fluid?
Old Oct 5, 2006 | 02:37 PM
chase123's Avatar
There was metallic residue when I changed it. Not really shavings, more like flakes.
The shops defense is that I already had shavings in my TC when they did the clutch install.
Old Oct 5, 2006 | 02:43 PM
Rnm's Avatar
Rnm
What shop was this?
Old Oct 5, 2006 | 02:45 PM
chase123's Avatar
Engine Logics in Houston
Old Oct 5, 2006 | 02:52 PM
DsmAwdTurbo's Avatar
haha thats not the shops defense, it happened 200 miles after you got your car back and they put the wrong gear oil in it. End of story their fault. They should have read up on what gear oils go where on the car. Stupid for them to put synchromesh in the TC. Good luck though. I dont think there will be an issue getting something out of them because they infact did screw up. Was it your first gear oil chage in the TC? Then I could see there being a little bit of shavings in there. I wouldnt really say shavings but material. Anyways, again good luck.
Old Oct 5, 2006 | 02:55 PM
chase123's Avatar
Yes, it was my first change at 3.5k miles.
Old Oct 5, 2006 | 02:57 PM
They dont have a leg to stand on. The transfer case was just fine until they did the gear oil change. They just had residue from the break in period. They owe you a new TC if it is infact toast.
Old Oct 5, 2006 | 03:00 PM
joeymia's Avatar
wait you needed a new clutch at 3.5k miles?
Old Oct 5, 2006 | 03:01 PM
chase123's Avatar
Unfortunately I don't really have a way of getting them to do the right thing.
Old Oct 5, 2006 | 03:03 PM
chase123's Avatar
Yes, it slipped one time and was never the same after that.
