Buschur Racing Or HPF GT35R Kit? HELP!!!
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by dryad001
buschur 3k kit is a better value for their money then the one your selling
2. I don't need a custom DP. That alone tells me HPF cant make something work with, well everyone elses DP. Wait a sec HPF offers a 3" DP, so lets say your a diehard HPF fan just as yourself. Now you went and bought their turbo kit and they give you a different DP along with the kit. Still with me? Now you HAVE to use the DP that came with their kit and now you have to go through the hassle of selling your other DP that you had to take off the car in order for the kit to function properly. IDK, sounds like a sales rip-off to me.
I here ya bud.....again we can't say it's a nice upgrade without the dynos and track times to match. What if the HPF kit only dynos within 10-15whp of Buschur's kit? Then you have this nice and shiny kit that is 300-500rpms laggier and doesn't produce the topend to justify the decreased spool. Then it's not a upgrade it's a degrade. Maybe HPF will post some new numbers and we'll have some hard data. Good luck.
Originally Posted by Pure Playaer
So wait ur saying i need a custom downpipe to work with BR GT35R? I cant use like.. a megan downpipe?
Ppl i also need some help
I am going for Buschur Racing Gt35R Turbo Kit.
The mods i currenctly have are,
HKS Intake,
HKS Carbon TI Exhaust,
HKS SSQV,
HKS Twin Plate Clutch,
FPR,
Walbro 255,
Blitz LM Intercooler,
HKS 272 Camshaft,
HKS Cam Gears,
HKS timing Belt,
HKS Valve Spring,
Blitz SBC I Color Boost Controller,
Megan Down Pipe,
Apexi Power FC,
HKS TT,
BR 1000 CC Injectors.
My car has done 40,000 Kilometers...So do i need to change anything?
Please advice
HKS Intake,
HKS SSQV,
FPR,
Walbro 255,
HKS 272 Camshaft,
HKS Cam Gears,
HKS timing Belt,
HKS Valve Spring,
Megan Down Pipe,
Apexi Power FC,
HKS TT,
Please advice
sonicnofabz, From page 2. Our kit is way overpriced? Are you completely out of your mind? Do you have any idea at all what you are talking about? Our GT35R kit is one of the cheapest on the market and has proven results. The entire kit is $2995.
Pure Playear got the BR kit, and I will be helping him with it. We will get a pump gas tune and a race gas tune both using EcuFlash, then we will go try to put down some great numbers at the track. Stay tuned!
sonic, again you are talking about crap on page 3. The picture of the kit you posted, take a good look at it. Do you see a manifold in that kit? Let me answer for you, NO. The kit uses the stock manifold with a turbine housing that is offset and has been proven not to work nearly as well as others. You are also comparing that kit to be a bargain at $2695 to ours for $2995 which comes with a ceramic coated cast manifold. Our kit has also been proven to run 9's at 142+ mph on a full street trim EVO on radials.
from page 4,
Markunknown,
I don't know you markourn but you are obviously a little dumb.
First off, we do use a GT3582RLSP turbo, this is the 4" inlet with surge ports just so you know. The turbo kit also uses a V-band 02 housing and the 44mm V band Tial gate. The kit also includes a Spal 12 HO fan, oil feed and return lines, V-band outlet for the wastegate, lower 304 grade stainless steel i/c pipe and our cast ceramic coated manifold too. I haven't seen your kits do anything, ours have already been proven for 9's at over 142 mph on EVO's in full street trim on radials.
There is NO need for a 3.5" 02 housing or exhaust, so putting one in your kit is rediculous. Our kit uses a 2.5" 02 housing which IS LARGER THAN THE OUTLET OF A GT35R and our 3" exhaust has run 9.7's at 150+ mph. Adding a 3.5" exhaust adds weight and expense.
You said to compare our kit to SBR's and not yours. Then added you forgot ours is proven. Well next time don't forget it newbie. When you start getting some real track records come back and talk until then we will compare YOUR turbo kit to SBR's as they haven't proven anything outstanding either.
Markunknown,
i had some bugs in that dyno run but the last dyno i had with no bugs was 506whp and 434 tq corrected
