Denso Fuel pump part # ?? 255lph?
Old Oct 6, 2006 | 10:00 AM
MR Dan's Avatar
anyone knows the part # for the 255lph or similar Denso FP?...
Old Oct 6, 2006 | 10:39 AM
Lancer EVO IX's Avatar
+1, and no walbro's please.
Old Oct 9, 2006 | 01:23 PM
MR Dan's Avatar
ok...i know theres some members here running these FP's.....part # / where to buy????
Old Oct 9, 2006 | 01:28 PM
Varrius's Avatar
http://www.z1auto.com/prodmore.asp?m...ine&prodid=144
Thank me later. Btw, the 310 lph FP is very nice for big turbo applications. Let her eat!
Old Oct 9, 2006 | 03:34 PM
ItalianEvo's Avatar
Go to a Toyota dealer and...
# 23221-46110
Old Oct 9, 2006 | 03:37 PM
mdsevo06's Avatar
Pricey
Old Oct 9, 2006 | 03:39 PM
Spec'd's Avatar
The Denso 310 lph FPwill fit into the stock fuel pump housing ?
Old Oct 9, 2006 | 03:41 PM
CO_VR4's Avatar
The Denso twin turbo Supra fuel pump serial number ends with 1020. It can be purchased for around $200, give or take, and combines quiet operation, OEM reliability, and higher flow than a Whinebro 255 (at least at pressures under 75PSI).
It is somewhat larger around than the stock Denso pump, though, and will take a little massaging to fit in the stock fuel pump location. There's a thread already on this topic if you use your search function.
Old Oct 9, 2006 | 07:37 PM
Spec'd's Avatar
Please provide a link to the thread about how a Supra pump will
fit into a plastic Evo housing with just a little massaging.
I think it's more like HACKING than massaging. I don't see how this
can be done without creating some sort of god aweful mutation.
The Evo pump housing is completely different than a VR4 or DSM.
Installation and modifying a metal VR4 or DSM housing looks like
a fairly easy process.
So once again we appear to have another ambiguous thread
about the Supra fuel pump not fitting the Evo properly. It also appears
that the Wahlbro is the only true drop-in replacement for the Evo.
Old Oct 9, 2006 | 10:02 PM
MR Dan's Avatar
# 23221-46110
yea i have read about the supra FP....have you installed one yourself?... that pump is way too big to fit our evos....someone show a pic of the actual install if its possible....damn whinebro getting louder everyday!!
Old Oct 10, 2006 | 12:23 AM
ItalianEvo's Avatar
Too big ?
I still have to receive it, ordered yesterday, but it should be only 10mm larger than the Wall Bros...
Old Oct 10, 2006 | 01:12 AM
turboDan's Avatar
Alot needs to modified to get the Supra TT pump to fit.You may want to think about purchasing a new pump housing before doing this as once you begin to modify so that the pump will physically fit,then the stock pump will never be useable in that housing again.
You must Remove the Filter assembly that is part of pump housing or it will not fit(and I dont mean the "sock"filter at bottom of pump).I have done this to an extra housing so Yes,I have done this and it is not a Butcher job but it is not by any means a "drop in" and did I mention that the wires that power pump need to have connector cut off and EyE ends crimped on.
Old Oct 10, 2006 | 06:35 AM
MR Dan's Avatar
Too big ?
show us your install when u get it....
Old Oct 10, 2006 | 11:42 AM
Spec'd's Avatar
What I find amazing is that so far my Walbro hasn't turned into a Whinebro yet.
It's been a few months in hot weather. So far so good.
Old Oct 10, 2006 | 06:58 PM
G-UNIT's Avatar
their is no way that is 310lph, someone who has bought one of these, please post the # stamped on to the top for me.
