Expected bhp of a gt37, on a 2.3ltr
Old Oct 7, 2006 | 06:43 AM
paul North's Avatar
What expected fiqures do you guys see with the above fitted, plus supprting mods, cheers
paul
Old Oct 7, 2006 | 08:28 AM
EVOlunchbox's Avatar
Not sure what "bhp" mine would be but my numbers are below with the set-up your talking about.
Old Oct 7, 2006 | 09:00 AM
-=SPECTRE=-'s Avatar
holy crap, evolunchbox. nice numbers. where in ga are you
Old Oct 7, 2006 | 11:19 AM
swordfish's Avatar
Which 37R? The AMS 37R or a real Garrett 37R.
jeff
Old Oct 7, 2006 | 05:59 PM
TopLevelPerformance's Avatar
Hey Jeff, whats the difference? thanks man
jeff
Old Oct 7, 2006 | 06:10 PM
sleet's Avatar
Different specs.
Old Oct 7, 2006 | 07:30 PM
swordfish's Avatar
Well, there are 3 garrett GT37R's and they are all BB and cant be had in a conventional bearing arrangement. They all use the same turbine wheel which is a GT37 84 trim but they use different compressors which are all GT40 based. The three compressors are 50 trim 82mm exducer, 56 trim 86mm exducer and a 52 trim 88mm exducer. This info is available on the Garrett website.
The AMS GT37R is kind of a slang name. I know it's a 67mm (inducer) compressor because I've measured one and I think the turbine wheel is a P trim.
jeff
Old Oct 8, 2006 | 12:22 AM
WhtEvo05's Avatar
Getting my set up back from AMS at Nopi in Norwalk after they installed new twin fuel rail system.
I'll get exact numbers an post them but from what Eric told me he said the car with safe tune made about 710 whp on C-16 and around 575whp on pump/meth.
Hope that helps.
Old Oct 19, 2006 | 02:49 PM
TKMotorsports's Avatar
AMS just made 762whp SAE corrected with their "37r" and 2.4 SRT-4.
Old Oct 20, 2006 | 03:10 AM
pjsevo8's Avatar
im gettin ready for the final tune. Ill let u guys know what my mustang dyno numbers are!!
Old Oct 20, 2006 | 07:12 AM
4ringturncoat's Avatar
How is yours on the street? You had a 35r before on a 2.0L, does the new kit spool like the old kit or better? BR has my motor done and now I need to decide if I want his 35r or the 37r. I am going with almost the same buildup as yours but a ported stock mani and tb.
Old Oct 20, 2006 | 08:27 AM
money pit's Avatar
i rode in his car at the shootout and it is crazy. either way you can't go wrong.
Old Oct 20, 2006 | 10:33 AM
It's MUCH better on the street compared to my old set-up. It's spools faster and harder. With the motor flowing much better (ie. head, mani's, etc) and having more displacement this thing is a beast on the street. You can't go wrong with either turbo.
Dave just ran a 9.97 on his 35R with the FP housing in full street trim. The way you drag race I wouldn't think you would have a problem recreating those numbers w/ a 35R.
On the 37R, @ 30psi. I was running 140MPH traps and ran a 10.8 (w/a 1.9 60ft) The car is going back two weeks from now for the new fuel pump 40-40+psi. tune. I have some turbo V8's down here I need to take care of.
Sorry for the hyjacking
Old Oct 20, 2006 | 10:44 AM
It looked pretty impressive for power from 4500rpm on up. I am thinking the 37r is the way to go, it looked like you were making 20psi @4500 which is about as good as most of the 35r's I have seen. My guess is 20psi on the 37r is a lot more air then on a 35r. Are you going with the dual fuel kit from BR?
Old Oct 20, 2006 | 10:56 AM
I am going with the duel fuel kit from BR. You will also need it if you plan on running high boost. I'm already running out of injector on my race gas tune, and meth+pump tune. I'm currently runnin Rc's 1200 cc injectors with a BR HO pump, and a fuel pressure regulator...
What happened to your Porsche idea?
razorlab
Jul 1, 2008 01:48 PM
hanahawaiian
Northwest Region
Jun 7, 2008 10:38 AM
GTisRule
Northwest Region
15
Dec 4, 2007 02:58 PM
Paul Nelson
Apr 2, 2007 07:34 PM
1slowevo
Northeast Region
47
Aug 7, 2005 04:31 PM
