Offical Mitsubishi Oil Filters
A cardboard bypass valve will not work as well as a metal one. So it could let dirty oil past the filter material.
That isn't a gamble worth taking on an engine in a $30,000 car.
Mitsu filters work, AND they are CHEAP!
Originally posted by wizardofoz
How do you safety-wire an oil filter?
Originally posted by ShapeGSX
Put a worm-gear band clamp around the oil filter. Tie some safety wire around the band clamp. Tighten down the clamp. Now fasten the other end of the safety wire to something on the engine block or oil filter housing such that if the wire were to get slack, it would only tighten the filter.
Originally posted by J'sLancerLS
People need to realize that ALL aftermerket filters have to meet and/or exceed manufacturers specs! Read the box the filter comes in, it'll tell if it does, and if the dealer says you HAVE to use their filter, they must provide them free of charge.
filter just to make sure there is no hassle later. I think it's kind of silly to think that only the
filters are any good.... That's an argument that all peeps make about their cars.. "only use Honda filters in your Honda, only use Subaru filters in your Subaru, ..etc.". I have the sneaky suspicion that most manufacturers filters are made by "outside sources" just like lots of other parts of the car.... Just for information, these "outside sources" often make their products under other brand names..... I don't know who makes the filters for
but there is a good chance that they might make the same filter under a different brand too....Still, just for safety, I'll stick to the factory parts for now... After all, $2 or $3 difference in price seems hardly worth the bother....
It does not use cardboard bypass valve.. it uses a cardboard endcap.. which really isn't too big of a deal.. unless it seperates..
But most of these filter elements are paper, and glued together, so there is just as much of a chance of that happening.
-Zach
OK, I'm done with this, people are driving me crazy!
Thomas Dorris
If you guys really think that there is no difference between a fram filter for example and a
filter... take 2 and cut them apart once. I think you'll be suprised.
cars are notorious for having tricky seals where the oil filter connects. Only
have the trick down pat.
http://www.cmfilters.com/
You guys should go with a canton mecca, it will save you cash over the life of the car and provide better filtration.
Don't waste your cash on those crap cardboard frams.
FS[West]: Evo 8 Mitsubishi Oil Filter Housings
SLVRNBLK
Mar 21, 2016 05:50 PM
FS[West]: Mitsubishi OEM oil filter.
DarkSyde294
Dec 22, 2015 05:59 PM
