Is this the "50 trim" that everyone's talking about?
Old Oct 11, 2006 | 10:57 AM
turboj's Avatar
Better said, which of these is the real "Pump Gas King"? They're all 50 trims, but which of them are the closest to, say, the AMS kit? I'm planning to buy just the turbo then buy or build my own manifold, but would the O2 housing be any issue? Do these have O2's that I can buy? Obviously, this won't be a prob with a 20g, but would it be a big problem if I just bought a turbo? Or does it come with it? Which parts should I buy and which should I build, which parts come with it?
Here are the links to the turbos:
http://www.slowboyracing.com/shop.php?sid=&cat=1333
http://www.slowboyracing.com/shop.php?sid=&cat=1267
http://www.atpturbo.com/Merchant2/me...egory_Code=GTB
Old Oct 11, 2006 | 11:10 AM
Waz996's Avatar
wouldnt you save urself the trouble and get it complete bolt on from Shearer? (their manifolds the best recommended, lifetime warranty..)
Old Oct 11, 2006 | 12:30 PM
RA42925's Avatar
i know what they are talking about when they say 50 trim
but what specifically does it mean?
how is it different than say a gt30r or gt35r ect..?
is it just a different sizing scheme?
Old Oct 11, 2006 | 12:55 PM
mooreboost's Avatar
It's inbetween the 30r and the 35r.
Don't hold me to it, but I think people say it makes alittle over 400whp on pump.
Old Oct 11, 2006 | 01:02 PM
KOEvo's Avatar
Yes there is a 50 trim in each of those links, though the "PTE" 50 Trims are not Garrett, and i personally have no idea how they work or if they are BB, and the ATP turbo may have their special hotside that bolts up to the stock manifold, which probably wouldn't be cool. The first SBR link has what your looking for i believe.
It is called a 50 trim Because it has a 50 mm cold side; im sure among other things.
Any Dual Ball Bearing Garrett 50 trim (50mm cold side) is the same as all the kits out there. The choice of .48 , .63 or .82 a/r is your own, i bet it's random which campanies use which.
Again, save yourself the money and buy a kit; a manifold alone is going to cost you a grand.
Old Oct 11, 2006 | 01:08 PM
Ev0ikon's Avatar
Hey, let the man build his own manifold. Be unique! :P
Old Oct 12, 2006 | 06:23 AM
240Z TwinTurbo's Avatar
It is a T3/TO4E
stage III turbine wheel
.63 a/r turbine housing
50-trim compressor wheel
You can get this with an optional ball bearing center section.
Old Oct 12, 2006 | 06:30 AM
TurboSpoolinIns's Avatar
Uh... PTE uses Garrett parts. The 50 in "50 trim" is just the trim of the compressor wheel. Trim is just a ratio of the inducer/exducer of a wheel. The inducer on the compressor side is 54mm. The turbo flows less than a 30R compressor but it's close. Some people have it rated from 46-49 lb/min. A 30R's compressor wheel flows 52 lb/min. A 35R compressor flows 65 lb/min.
Old Oct 12, 2006 | 11:59 AM
KOEvo's Avatar
Learn something new ever day .
At least i gave it a shot, and was fairly close .
Old Oct 12, 2006 | 12:39 PM
High_PSI's Avatar
I would stay as far away from ATP as possible. AMS is top choice even thoughthey charge $1000 to much. Just get teh Buschur kit, $3000 grand, same whp and a stock looking manifold, very sleeper.
Old Oct 12, 2006 | 12:43 PM
evo_il8's Avatar
AMS and Turbotrix have been proven for 500
Old Oct 12, 2006 | 12:45 PM
4WS Tuning's Avatar
get a kit...perfect fitment... and some1 to call if something goes wrong..
Old Oct 12, 2006 | 12:50 PM
I'mStock's Avatar
If you don't know what you're talking about 100%, then don't say anything. That's one of the main reasons there so much bad info floating around EVOm, everyone here "knows a little bit".
Old Oct 12, 2006 | 12:51 PM
boomn29's Avatar
+1. You mentioned the AMS 50 trim; get it directly from them with no worries.
I don't foresee 500whp on pump gas. Maybe 500hp crank. I think it's more like 375-400whp with near stock spool-up. That's nothing shabby! If you add in meth or higher octane gas you could work towards 400+whp I believe.
500whp comes from something bigger like a 35r from what I've read.
Old Oct 12, 2006 | 12:59 PM
Jasil's Avatar
It's a very pump gas friendly wheel. Very good efficiency at 23lbs and can achieve 500whp in a proper combination. It's always out powered the larger 60 wheel on pump gas and the old FP Greens are legendary in the DSM world.
I would put my money on a pump gas 50 trim over a pump gas 35R any day of the week running the same boost.
