clutch install question
Old Oct 11, 2006 | 04:10 PM
joseph143's Avatar
My friend and I are replacing the clutch in his car this weekend and I had a question. When we get the assembly out should we use some type of degreaser, carb, or brake cleaner to clean it before we install the new clutch? Does it matter wheather or not its cleaned? Also is there any where that you wouldnt want to mess with, for example the flywheel?
thanks for all your help... and for reference its a 04 evo 8 and he's just replacing the disk.
Old Oct 11, 2006 | 04:26 PM
Kerr's Avatar
Fomer Vendor
If your reusing the stock flywheel you should have it resurfaced. And if you talking about cleaning the pressure plate...don't think theres a point to that. And I think it would be a good idea to change the throw out bearing too(if you haven't thought about that already).
Old Oct 11, 2006 | 11:05 PM
joseph143's Avatar
yeah.... well aware of all that... its not it a twin disk..... I have the enitre maintance manual from the dealer so i got most of that covered.... I just wanted to know if there was a good reason the flywheel pressure plate and some one meantioned the bell housing... I havent worked with to many Manial Transmissions before... I think i have changed a total of two... but one a chevelle and a ford ranger. just looking for some advice anything is appreciated
Old Oct 12, 2006 | 01:42 AM
joseph143's Avatar
lonely late night bump!
