normal driving ?
Old Oct 12, 2006 | 11:35 AM
06redMR's Avatar
normal driving ?
at what RPMs do you guys recommend switching at when daily driving? im not sure if switching too low is bad for the engine or whatever but im sure you guys all would know the answer. i switch at about 3-3.5k , would u guys recommend switching at a higher RPM when commuting , or does that sound fine to you guys?
Old Oct 12, 2006 | 11:38 AM
tripperfx3's Avatar
Read the service manual. It tells you in there when to shift for the best gas mileage. With my GSR i shift at around 3k or jus a little less. The 6 speed may be different due to the change in gear ratios.
Old Oct 12, 2006 | 11:45 AM
Pure Playaer's Avatar
in my mr i daily drive to 3.5-4k rpms for smoother shifting and driving
Old Oct 12, 2006 | 11:50 AM
Bdub25's Avatar
i switch at 8k
Old Oct 12, 2006 | 11:54 AM
tripperfx3's Avatar
Originally Posted by Bdub25
i switch at 8k
In the Evo or on the bike?
Old Oct 12, 2006 | 12:03 PM
Smike's Avatar
Normal driving? Listen - did you by an Evo for its MPG? No.
Shifting too low bad for engine?...geez, yep if you shift at lower than 3k it goes boom!
Shift whenever. You want to go to 7k then shift, go ahead.
This thread is pointless. No, I havent had my afternoon coffee, and its a currently a blizzard outside.
Old Oct 12, 2006 | 12:06 PM
BretTheJet26's Avatar
anything under 3K is way too low IMO.. i shift at 4K
Old Oct 12, 2006 | 12:08 PM
jqturbo's Avatar
I shift at 3K or a bit less myself.
Old Oct 12, 2006 | 12:26 PM
Ragnarok's Avatar
I usually shift a little lower than 3k in 1st, and then at 3k in every other gear. I am so slow in my driving style that I am sure people get annoyed by me.
Old Oct 12, 2006 | 12:28 PM
Rnm's Avatar
Rnm
I drive the same way.
Old Oct 12, 2006 | 04:34 PM
icecream6's Avatar
now thats funny
Old Oct 12, 2006 | 04:37 PM
Paul Nelson's Avatar
i put a bigger turbo on for better mpg
Old Oct 12, 2006 | 04:47 PM
thisxguy's Avatar
i shift between 2.5-3k rpm. if the engine is cold then i will drop my shift points a little lower
i try to shift before or at 3k so i stay out of peak boost area (3500rpm)
Old Oct 13, 2006 | 11:36 AM
kilgoja's Avatar
i shift between 2.5-3.5k...especially when cold...and in extreme situations like pulling out in traffic etc. i shift at about 3.5-4.5k....there really is no need to shift at higher rpms...max torque is at 3.5k
higher rpms will just rag your car out faster....if you bought the evo and you're racing in events all of the time then go for it
Old Oct 13, 2006 | 11:37 AM
michaeljr6's Avatar
all depends on my mood. some days i get happy and shift high....tired...i try to shift early to save time..
