Flutter at WOT
Old Oct 19, 2006 | 08:40 AM
  #31
Evo VIII Black's Avatar
05 Apexi Silver EVO
BR TBE, Greddy RS BOV, Exedy Stage 2 Clutch, HKS RS Intake, soon to be installed, Perrin Front Mount w/ full piping, GSC272/264 cams!! WOOHOO! hello 350whp!!
oh and not to mention my bad azz Cool Perrin Antannae
Change your mods list cause the last time I checked all your stuff was installed.
Old Oct 19, 2006 | 09:03 AM
  #32
vwjeff's Avatar
My car does the samething at 29 psi, anything under 25 and I am cool after Al tuned my car. I have a 1g but its not crushed. I was thinking I should crush it
Old Oct 19, 2006 | 01:49 PM
  #33
funnyclub's Avatar
Originally Posted by Evo VIII Black
Not really. It seems to do it only when you build boost slowly like on the highway and you go to pass someone if you know what I mean. I have launched it from stop to 90 mph and did not do it.
The car has 18500 on it now. So from your post I would have to say no because when cruising in 5th and then go to pass someone it will do it.
My car is the exact same if I build boost from a low rpm in a high gear it happens. Also my boost is set to 1.6 boost and if i go hard through all the gears its fine but sometimes now instead of fluttering it sticks a 1.4 bar instead of going to 1.6 bar.
I have a feeling it could be the actuator. But i am not sure not really to bothered as I will be fitting a ams gt35r in a few weeks.
Old Oct 19, 2006 | 04:52 PM
  #34
Yeah mine does the same thing on boost. Good luck on the turbo. Can't get a new turbo yet g/f would kill me if I spend another dime on the car with out getting her that special rock.
Sorry just a little of topic just had to say it.
Old Oct 19, 2006 | 05:00 PM
  #35
Ok everyone thanks for all the help trying to solve the problem.
Now for the solution to the problem............and a lesson learned.
The Lesson
Make sure your instruments are working correctly. Namely your boost gauge.
I replaced my boost gauge and WTF... the new one was showing that I was boosting 25psi. the old one was showing 20psi. Lowered boost and what do you know no more fluttering..... its amazing.
Old Oct 19, 2006 | 06:16 PM
  #36
RevMoto's Avatar
Nice, what gauge gave you the problem?
Old Oct 19, 2006 | 08:17 PM
  #37
AutoMeter Carbon fiber and had it less then a year. Going to be making a phone call tomorrow. Replaced the old with the same one lets see how long this one lasts.
Old Oct 19, 2006 | 08:37 PM
  #38
TTP Engineering's Avatar
It pains me to see all these responses. All I can say as at least it seems people are giving it their best shot.
Change your boost controller.
Old Oct 19, 2006 | 09:03 PM
  #39
sparky's Avatar
So....what exactly is causing these cars to buck at 25#+ ?. I'd like to understand. Is it a fuel delivery problem, is it the WG...or what? When the thread starter wants to finally go to the track and run more than 25# boost will he run into this same problem? I mean, the problem will reappear if he cranks up the boost past 25# won't it?
Old Oct 19, 2006 | 09:56 PM
  #40
Problem has been solved............ Its not my boost controller it was my boost gauge.
Old Oct 19, 2006 | 10:00 PM
  #41
My car never bucked just the BOV fluttered. The BOV was doing its job.... the stock one that is
Old Oct 19, 2006 | 10:07 PM
  #42
Explain to me how your boost gauge causes your BOV to flutter.
Old Oct 19, 2006 | 10:10 PM
  #43
From an earlier post of mine
Explain to me why you can't read.............
Old Oct 19, 2006 | 10:27 PM
  #44
Explain to me how you don't understand what you just did.
Your boost guage did not cause your BOV to flutter, genious. In fact your BOV was not fluttering at all.
You were overboosting due to the cheap parts you bought and or installed incorrectly. Autometer is crap, especially when you install the cheap plastic hose and not a real vacuum line and barb.
Old Oct 19, 2006 | 10:43 PM
  #45
Yes I was overboosting. Why? Because the boost gauge was reading the pressure in correctly. So that being said genious.... As cheap as the gauge may have been or is it was the primary cause of the problem. Why go and by a new boost controller when it was not the primary cause. I found the primary cause of the problem and rectified it........ problem solved........lesson learned.
As for Autometer being crap thats your opinion and like A$$Holes everyone has one. And just for the record I am using real vacuum hose not the plactic stuff.
