Flutter at WOT
Old Oct 20, 2006 | 12:16 PM
  #61
Evo VIII Black's Avatar
Originally Posted by TTP Engineering
You solved your own problem reversing what caused it in the first place. Your 25+psi boost setting and proceeded to turn down the boost.
Overboosting would indicate a boost controller problem.
Your gauge malfunction is not the cause, but an effect of a poor install or faulty product.
Fluttering was not BOV flutter at all, but likely compressor surge and/or timing retard from detonation caused by overboost.
Then please explain the four different fluttering noises, each from a different BOV. Cause I now each one has it unique sound. I have the old forge BOV with the springs and at part throttle the thing flutters like a *****. It also fluttered the same way when I overboosted. So again where was the fluttering coming from.
Old Oct 20, 2006 | 12:22 PM
  #62
You know what man I don't even care anymore. I am not returning to this thread anymore. Everyone claims to be experts and just turns into an arguing match. This is stupid........Someone please close this thread.
Old Oct 22, 2006 | 08:26 PM
  #63
olsookie's Avatar
lol FIGHT!!!!!!!!!!!!!!!!!!!
Who wants to dance w/ Pernell? haha!
wow, never would think a vendor would get into a tussle like that...
atleast the problem is fixed, that's the only thing that matters.
Old Oct 22, 2006 | 10:15 PM
  #64
jqturbo's Avatar
Originally Posted by Evo VIII Black
...I replaced my boost gauge and WTF... the new one was showing that I was boosting 25psi. the old one was showing 20psi. Lowered boost and what do you know no more fluttering..... its amazing.
You said this now, but quite a few posts back, you said you had already tried this and no luck!? How many boost gauges did you try??...
...Up till this point I have done most of the simple logical troubleshooting with no luck. Check Plugs and gapping, Boost leaks, Changed BOV, Changed MBC, Even swaped out Boost Guage, Reflashed with old mail-in flash, checked base timing, even moved my source boost to BOV hose from intake...
The thread says flutter at WOT, but then you say it was fine when you gun it in all gears, but it fluttered at cruising speeds once you're building boost in low rpms!? Which is it??
By the way, did the "flutter" stop when you let off the throttle?
Old Oct 24, 2006 | 02:56 PM
  #65
olsookie's Avatar
he only tried one boost gauge until his last troubleshooting piece was to replace the gauge, when he did that he saw he was boosting way too much.
the flutter did stop when he let off the gas.
S2K2EVO
Jan 25, 2012 09:34 AM
EVO8LTW
13
Sep 1, 2010 07:06 AM
evo unknown
Oct 19, 2009 08:29 AM
evoseller888
16
Apr 27, 2009 03:55 AM
dean_anderson
27
Jan 14, 2006 01:13 PM
