ATS vs HKS twin carbon clutch
These are the 2 Im thinking about, but the only thing i cant seem to find, is if the HKS max twin is full carbon or a carbon/mettalic mix? If it is mixed, I would rather go with the ATS as I know its not mixed. Does anyone know if the HKS is full carbon or not?
https://www.evolutionm.net/forums/sh...11#post3323611
Originally Posted by jmartinez1170
Why dont you look it up the hks-usa.com
Heres what that site says about it
"The HKS GD Clutch Max is the latest evolution of the HKS multi-plate clutch series. The GD Clutch Max features the same multi-plate design and lightweight flywheel of the GD Clutch Pro, but also features a sprung hub (on most applications) and special engagement springs (patent pending). The sprung hub absorbs engine torque which helps increase the life of the transmission, and aids in decreasing gear noise. The engagement springs are placed between two pressure plates and the center plate. --- They force the clutch plates to engage one at a time. Doing so makes it easier to slip the clutch, improving street drivability and clutch control.
The HKS multi-plate performance clutch kits are vehicle specific Pull-Type racing clutch applications designed for street-car use. The multiple plate design allows increased friction area and direct power transfer, thus offering greater horsepower and torque holding capacity and light clutch pedal pressure for easier clutch pedal management. The use of rivet-less clutch disks allow for better durability, increased friction area and direct torque transfer, while maintaining a friction material that is both wear and heat resistant. Each multi-plate clutch kit comes with a lightweight chrome-moly flywheel optimizes durability and high performance. The use of very durable and lightweight chrome-moly material with a steel tooth ring makes it possible to construct a thinner flywheel without sacrificing integrity. The concept behind a lightweight flywheel stems from the desire to enhance low-rpm throttle response on high RPM horsepower applications. With the lightened flywheel in the HKS Twin and Triple Plate Clutch kits, a quick rise in RPM can be attained from light throttle input for easier RPM matching when downshifting and to counter low torque at low RPM levels. Though the main focus of the HKS multi-plate clutch kits is on ultimate power transfer and engine response, a stable idle and smooth driveability is still maintained. Each HKS Twin and Triple Plate Clutch kit is a complete vehicle specific assembly that allows for a bolt-on installation. Some applications have an available slave cylinder rod that increases travel for enhanced pedal modulation."
the word Carbon is not in that, so, how would I even know if its mix? lol
Originally Posted by cnoevo8
here is the ats
Isn't ATS now Carbonetics?
No answer for you on the HKS, sorry.
But either way, Tilton whips them both if this is going to be a serious racecar. Low inertia is where you want to be.
Well, if it is Carbonetics, then they dont have very many online , because when i do a search on google, nothing really comes up. But ATS does, are you sure they changed the name? I would love a tilton, but one, I cant seem to find any for sale, and two, the price is insane, for what i can find.
This is the same clutch ill be running on my 600+whp build i put the plus becasue i dont really want to post what im going to run but it will be about the limit of what the setup is rated for so i will put it to the test.
Vigman
Jan 20, 2011 11:55 AM
m4tt VIII
Apr 15, 2009 04:15 PM
