Oil where it shouldn't be (PICS)
Old Oct 17, 2006 | 10:30 AM
Exciting News's Avatar
Doing some work last night (TBA) and saw this. My instinct tells me this may be a result of headstud install (which would bother me since I paid a reputable shop). Am I right? If I am, can retorquing them solve the issue? Just in case anyone asks nothing is coming from the valve cover.
Old Oct 17, 2006 | 10:44 AM
tony gibson's Avatar
Could be blow by....I don't think headstud install would cause this....if you pushed coolant I would lean toward headstud install....Leak down test would be on my list of things to do...Good luck.
Old Oct 17, 2006 | 10:48 AM
idriveanevo's Avatar
i installed my studs and there was oil coming from the bottom center on mine...
Old Oct 17, 2006 | 10:50 AM
Pure Playaer's Avatar
+1 to the test
Old Oct 17, 2006 | 10:53 AM
tarmac4g63's Avatar
If it was cause of the headstuds it would normally be coolant that you would see leaking you should run a CLT
Old Oct 17, 2006 | 10:54 AM
tripperfx3's Avatar
I dont think blow-by would be that bad... Did you check to see how much oil you might have lost? If it is the headstuds take it back to the shop and have them order you new headstuds and re-do it. You cant just re torque the headstuds. They are designed to strech once you install them. You'll have to get new ones.
Old Oct 17, 2006 | 10:57 AM
vroomevo's Avatar
hmm, i have very similar problem. i see oil-like spots just around junction btwn exhuast manifold and engine head. haven't paid much attn to it.
btw, what is the blow by?
Old Oct 17, 2006 | 11:08 AM
Blow by is when the piston rings are washing out and oil gets past them and makes it to the combustion chamber...Like when you have a catch can hooked up to your crank case breather and it fills up with oil....That is normal crank case pressure....but if it makes it to the exhaust mani, that is bad lol
Old Oct 17, 2006 | 11:35 AM
vroomevo's Avatar
so, to test for the blow by, then compression test is the way to check it, right?
if there is the blow by, what's the solution to fix? new piston and ring?
how much this will affect the performance?
Old Oct 17, 2006 | 11:41 AM
Az3ar's Avatar
Same happened to my older EVO . It was the head stud Install.
Old Oct 17, 2006 | 12:51 PM
mchuang's Avatar
You could also test for blowby by turning car on and then open oil cap and see if lots of white smoke pours out. Becareful though as oil can jump out slightly too..
Old Oct 17, 2006 | 12:56 PM
tarmac4g63's Avatar
Actually blow by is when combustion gases get past the rings and go into crankcase
Evotech8's Avatar
After the initial headstud install did you heat cycle the engine and then re-torque again to 85 ft.lb?
This is a important step as I've noticed the torque setting can loosen a little after a heat cycle.
If its not too late you might try popping the valve cover and re-torque.
Old Oct 17, 2006 | 12:59 PM
Hmmmm. No consumption as I can tell. Just changed the oil yesterday, so I'll monitor the level. There was oil in the intake right in front of the turbo. Very little smidge. Blades were dry. I do have a catch can and it was bone dry when I checked it (the clear lines a filmed over and that's it). Some people are saying "yes" to headstuds while others are saying "no".
Old Oct 17, 2006 | 01:21 PM
TTP Engineering's Avatar
Looks like headstuds should be retorqued.
