5 bolt turbine housings
Old Oct 18, 2006 | 09:24 AM
Noogles's Avatar
Are these the garret "ford" 5 bolt housings? does anyone have a part # for .83 Ar 5 bolt housing?
Old Oct 18, 2006 | 09:35 AM
RoadSpike's Avatar
Just to make things clear
This is a 4 bolt
This is a 5 bolt (ford style)
EDIT:
Yeah i forgot to mention we use the 5 bolt style for an OEM turbo
Old Oct 18, 2006 | 09:50 AM
Noogles's Avatar
I need to get a 5 bolt turbine housing for my 35r what housing do i go with?
Old Oct 18, 2006 | 10:01 AM
RoadSpike's Avatar
I'm just curious as to why you "need" a 5 bolt housing the only percievable benefit would be that it keeps the stock 02 outlet and downpipe.
The kits i've seen for a gt35R have a flange style outlet and usually come with all the hardware, manifold, downpipe,wastegate...
BTW its a pretty well known fact that the 5 bolt housing is more restrictive than a 4 bolt or flange style.
Old Oct 18, 2006 | 10:07 AM
Noogles's Avatar
reason being is the measurements on the manifold were taken incorrectly and the only way to add a 3" DP is to remove the AC. This is a One-off kit.
Did you know that Shearer Fabrications claims more power with the 5 bolt of the 4?
Old Oct 18, 2006 | 10:27 AM
RoadSpike's Avatar
Thats cool that shearer can make more power with the 5 bolt
Sucks that you didn't get the proper manifold measurements.
I looked through garrett's main site and didn't find and option for a 5 bolt, maybe someone makes a custom housing
Old Oct 18, 2006 | 10:39 AM
Noogles's Avatar
I called ATP and they were able to hook me up with one, It does suck but i think i fixed the problem.
Old Oct 18, 2006 | 10:40 AM
RoadSpike's Avatar
sweet
Glad you found a solution wish you luck
Old Oct 18, 2006 | 11:31 AM
AlwaysinBoost's Avatar
wish I would have seen this sooner as I have an extra .63 5-bolt housing sitting around I would have let.
I don't know how much truth there is to the 5-bolts being less capable then the 4-bolts. It makes sense that the 5-bolt should spool slower since its more 'on-center'. However if you look at the GT35r spool up thread you'll see my 5-bolt housing on my bone stock 2.0 is spooling like a 2.3l stroker down low... so how knows for sure.
thepoint4life23
Apr 20, 2016 10:20 AM
2006IXWW
Oct 12, 2015 06:41 PM
evotuner04
15
Apr 16, 2008 02:28 PM
crcain
Aug 9, 2007 01:57 PM
SS RX7 r2
May 27, 2005 10:10 AM
