hks cams and cam gear questions
hey,
im putting hks 280/280 cams and adjustable cam gears in my 04 evo 8 and was wondering if its necessary to replace the valve springs and valves with aftermarket? will it mess up the car if i dont do that?
pm me
thanks,
geoff
pm me
thanks,
geoff
No need. Dont over rev it and you will be ok
Originally Posted by STIGOD
hey,
pm me
thanks,
geoff
pm me
thanks,
geoff
HKS cams are totally fine with the stock valvetrain. If you want to upgrade your valvetrain, I would consider some higher lift cams (such as revolver), you will see a lot more gains with higher lift numbers if you want to spend the $$ on the valvetrain. As for 280's in my opinion they are a bit too aggressive with use on anything smaller than a GT3X series turbo. Have you looked at the Helix 272's and gears? They are lighter and you'll get much better idle than the HKS 280's. We also have an HKS 272 special going on, give me a PM.
Cheers,
Gary
Gruppe-S
Cheers,
Gary
Gruppe-S
blackevolution8
19
Jan 11, 2010 12:10 PM
PHILLY EVO
19
Mar 7, 2009 05:41 PM
AMSTuning.com
Mid-Atlantic Region
Feb 12, 2005 08:12 AM
