zeitronix meter.............
Old Oct 25, 2006 | 05:01 PM
06redMR's Avatar
does anyone use the zeitronix ZT-2 as a boost/EGT/throttle position gauge in addition to the A/F meter???? im looking at it and i was wondering how i can make it read all of those things as opposed to just A/F because i noticed that it has the ability to do so ... anyone have any expereince with the unit ?
Old Oct 26, 2006 | 10:47 AM
TTP Engineering's Avatar
What do you need to know?
Old Oct 26, 2006 | 11:37 AM
BADEVO's Avatar
I use it with the additional EGT and Boost options and it is hands down the best unit I have run. It consolodates all functions into one clean simple easy to use set up. Worth its weight in gold.
I got mine from TTP as well.
Old Oct 26, 2006 | 11:43 AM
vboy425's Avatar
the only thign will display on the LCD screen EGT,AFR,PSI and lambda. if you are talking about the softwares. go option and put a check what you want.
Old Oct 26, 2006 | 12:49 PM
BigBallin's Avatar
got pics of it installed?
Old Oct 26, 2006 | 01:03 PM
Old Oct 26, 2006 | 01:06 PM
idriveanevo's Avatar
wow... how much is the entire system... with all options??
Old Oct 26, 2006 | 01:10 PM
Ev0ikon's Avatar
Originally Posted by TTP Engineering
Nice!
I'll paint mine black too so it won't stand out too much.
Old Oct 26, 2006 | 01:12 PM
ive looked and i cant find out what lambda is for...
ROCK's Avatar
It does it all and Zeitronix is the best. We sell them, we use them..... It is the right choice.
ROAD/RACE
kimletrim's Avatar
Registered User
The display is also available in black directly from Zietronix ^^^^
Old Oct 26, 2006 | 01:22 PM
Originally Posted by Ev0ikon
Nice!
We ONLY stock black LCD displays.
25 in stock, ready to ship!
Old Oct 26, 2006 | 01:35 PM
RoadSpike's Avatar
Lambda in simpleton terms is a function with a single argument (X) that relates to an output.
In the O2 sensors case Lambda is really a function of 1 = 14.7:1 AFR
the higher the AFR the higher the lambda
the lower the AFR the lower the lamda
Ironically this is a function of the INVERSE of the voltage from an O2 sensor.. Think of it as effeciency of the statiometric AFR..
here's an output example
HTML Code:
volts      air/fuel     Lambda                (open circuit)
0.250       15.0:1       1.02
0.375       14.5:1       0.99
0.500       14.0:1       0.95
0.625       13.5:1       0.92
0.750       13.0:1       0.88
0.875       12.5:1       0.85
1.000       12.0:1       0.82
Old Oct 26, 2006 | 01:39 PM
GOT IT!! like on the aem a/f gauge.. thanx
Old Oct 26, 2006 | 02:02 PM
evo150's Avatar
i know that it logs alot of parameters, but does it log timing aswell?
