do you need an upgraded ECM to run cams
Old Oct 25, 2006 | 08:18 PM
Evoluvin's Avatar
I was looking into geting the HKS 280' s or the 272's but i havent made up my mind yet... i was wondering if i need to run an upgraded ECU to run these cams... i know i dont need an upgraded valvetrain.....
thanks
Anthony
Old Oct 25, 2006 | 08:21 PM
EVO8904's Avatar
I would go ahead up grade the valve train, BC valve train is a good price. I would also get some kind of EM.
Old Oct 25, 2006 | 08:24 PM
ace_2822's Avatar
Its called a flash!
Old Oct 25, 2006 | 10:09 PM
evo150's Avatar
what mods do you have done so far? most likely 280's are going to be overkill but whether you go with 280's or 272's youll need to have your ecu tuned (flashed) for optimum drivability and power
Old Oct 26, 2006 | 11:02 AM
Evoluvin's Avatar
ok thanks guys what flash do you recommend
Old Oct 26, 2006 | 11:27 AM
yellowEVO21's Avatar
searching is your friend man....plenty of threads from guys in your position looking for a "good" flash.
Old Oct 26, 2006 | 05:30 PM
go_evo_go's Avatar
I went with TTP, but there are a slew of flashes out there. Its best to check websites to see staged upgrades that you need to support this kind of mod. Buschur is a good place to start. But there are others as well.
Old Oct 26, 2006 | 06:13 PM
Sgt Blamo's Avatar
A tune & supporting mods. If your in MD. then you should be close to AMS or Buscher, I would go with someone near by in case you have a problem, that way you don't have to send your ECU out and have down time or worse.
Old Oct 26, 2006 | 06:18 PM
EVO8904's Avatar
Originally Posted by ace_2822
Its called a flash!
EM stands for Engine Management and a flash is a form of EM.
Old Oct 26, 2006 | 10:00 PM
ace_2822's Avatar
Thanks I had no idea what EM stood for
Old Oct 27, 2006 | 05:11 AM
BANKS 2's Avatar
i have aem ems in my car with comp 280's.. when i took out the aem the car would not run with the 280s and a factory ecu... it stalled out every 30 seconds and rode terrible. but on a flash it would be fine, youll just notice a lumpy idle.
