Lots of vibrations thru clutch pedal...uh oh?
Well I just recently had an Exedy Twin installed in my '03 evo about 1,000 miles ago.
Now it sounds like my throw out bearing is shot again and i can feel a ton of virbations thru the clutch pedal....this is fkn gay!
I have not beat on the car at all and broke it in correctly and tob is shot already?! What would be casing this? Is there anyway the technician can put this in wrong? And also if i dont let it out right, it will make a shudder noise when taking off. I already got a stiffer front motor mount and it helped alot but it still kind of does it. Im guessing i should go ahead and replace the others ones too?
Thanks
-Ryan
Thanks
-Ryan
chatter at idle when the clutch is released? i really havent payed attention to it until now. but can someone else verify this? i know it makes noise when in gear and i let off the gas.
anyone else with an exedy twin that can feel vibrations thru the clutch pedal? i would not think this is normal?
strtrcng426
Aug 16, 2010 10:12 PM
silverevo05
13
Nov 5, 2007 07:07 PM
tehforbes
Dec 28, 2006 06:22 PM
