Clutch pedal only comes up half way!
Old Aug 16, 2010 | 09:04 PM
strtrcng426's Avatar
hey guys im having a problem with my clutch pedal after I installed a quatermaster twin disc and steel braided clutch lines. When I drive my car and go to change gears, sometimes it will just come up halfway. I can put my foot under the pedal and pull it back but there is almost like a dead spot. My car does have 103k and I tried bleeding the clutch but when I open the valve while holding the clutch down and close it back up, I get no pressure at all. I opened the valve open and pumped the clutch to see if there is pressure thru the line, and after 20plus pumps finally a stream of fluid will come out. I can be wrong but almost feels like there isnt enough pressure. Did anyone have similar problems ? please let me know. thanks! Also if I go to boost my car, the pedal will come up all the way from half point. I cant figure out what could be the problem.
Old Aug 16, 2010 | 10:12 PM
one4's Avatar
sounds like there is still air in the lines... i cracked my stock line and replaced it. bleeding it was a hassle.
red_evox_87
Mitsubishi TC-SST Discussion
Jun 13, 2016 09:00 AM
evilution09
Sep 6, 2010 11:19 PM
bustin
12
Aug 8, 2009 10:22 PM
Dubius
Feb 25, 2008 05:09 PM
shiftdsm E
Sep 12, 2007 10:37 PM
