GSC EVO 9 CAM RESULTS DYNO'S Inside!
Old Nov 1, 2006 | 08:03 PM
vwjeff's Avatar
Originally Posted by GregGSC
how bout tomorrow
If you get me a sound clip with that... YOU WILL HAVE AN ORDER, TOMMARROW
This thread is b*tchin compaired to the last one, were AMS did the install.
Old Nov 1, 2006 | 08:04 PM
Warrtalon's Avatar
I have the Forge WGA (VIII version, of course), and although it does its job, it is not a substitute for an MBC, imo. We'll see how it works, but I have used MBCs for 8 years and without any hassle. IXs make great power with with good boost gains, so hopefully you can get the boost dialed in where you want it with the WGA. It just sucks having to take the WGA arm off and tighten (or loosen) the turnbuckle just to get to the desired maximum boost level. If you have small hands and great dexterity, you can do it without removing the radiator or anything, but otherwise it's an arduous process.
Old Nov 1, 2006 | 08:05 PM
MR. Birdie's Avatar
not bad, let start seeing some cam adjustment on the exhaust side and a more aggressive tune with the boost up!
so far its looking good
Old Nov 1, 2006 | 08:14 PM
GregGSC's Avatar
you see we got this kid named LC AKA LiL China. He's got hands like a 7th grade girl. LOL LC i got another job for u!
lol Leh's editing it now figured we'd surprise you this evening.
Old Nov 1, 2006 | 08:15 PM
GregGSC's Avatar
that would require a cam gear on the exhaust we can only move the intake cam with mivec... now the boost going up is going to happen!
Old Nov 1, 2006 | 08:25 PM
Warrtalon's Avatar
VWJEFF, go on with your bad self. Get these cams and rock out!
Greg, back when I was in the DC area, my local shop sponsor VIP Garage had a little Cambodian guy who was awesome and did these exact things for me. I watched him adjust my turnbuckle without removing anything and while the car was hot from me just arriving. He was the man, so I would bring him huge Chipotle burritos with extra hot sauce. That little 130lb bastard could out-eat my 225lb ***, and I eat like a horse. Anyway, I don't have anyone like that to rely on here in CO, so it's tough, hah.
Old Nov 1, 2006 | 08:43 PM
GregGSC's Avatar
GSC EVO 9 CAMS at Idle....and Leh got board with the GT3 RS so we put that at the end!
http://www.gscdownloads.com/evo9test...camsatidle.wmv
Old Nov 1, 2006 | 08:44 PM
GregGSC's Avatar
LOL sounds just like LC bastard can eat like no other.
Old Nov 1, 2006 | 08:50 PM
thisxguy's Avatar
looks good
Old Nov 1, 2006 | 08:52 PM
GregGSC's Avatar
vid was a lil boring.... so i kikd it up a notch....
Leh.....
Old Nov 1, 2006 | 09:01 PM
vwjeff's Avatar
[QUOTE=Warrtalon]VWJEFF, go on with your bad self. Get these cams and rock out!
QUOTE]Explain this to me, so I don't have to come a beat your a**
Old Nov 1, 2006 | 09:07 PM
SmokinJoe's Avatar
Doug at top speed should have some 280/280 numbers for us next week with the 3076 kit
Greg -
I was in the process of installing (just minutes ago) the 280's when I ran into a slight snag. I wasn't prepared for the Mivec sprocket bolt, which appears to be a 12mm hex. The largest socket I had was a 10mm hex. Can you confirm that is correct size?
Once I pick up the right tool tomorrow, we should be back on track to have these tested and the numbers up on Friday around lunch time. We're going to spend time tuning the MIVEC. The MIVEC changes will be posted along with a baseline v. final 280 graph.
The 280 combo makes power @ 4,500 which is dead on where the 3076R spools. This should be very interesting
vwjeff's Avatar
Thanks Greg, it ain't what I wanted to hear in terms of them being choppy... it sounded stock
Oh well, I like the #'s so I'll call you in the morning
Also you have PM.
Old Nov 1, 2006 | 09:13 PM
GregGSC's Avatar
Originally Posted by SmokinJoe
Greg -
14mm hex. 32nm or 23ftlbs torque spec. DO NOT OVER Tighten it make sure you got a good tq wrench
Old Nov 1, 2006 | 09:15 PM
GregGSC's Avatar
Also you have PM.
I set the idle at 1000k rpms to get rid of the lump. if you want it just set it at 800 and you will here all you want
