Walbro 255lph Questions
Old Nov 4, 2006 | 07:54 AM
ashumo's Avatar
Well I installed a 255lph without the install kit. We throw as much fuel as we could @ peak tq and still was running lean. Decided to use the install kit and found all our fuel that was leaking by the rubber grommet cause the stock piece below the pump allowed it to push out a bit. The stock rubber piece that is below the pump is half as thick as the walbro one. So we found all our fuel after that. More fuel, more boost...Problem solved.
Now Ive noticed a couple things. I dont hear that inital prime that I heard with the stock pump...Is this normal? My starting is kinda random last night it was crank crank start like 2 secs or so.
Does everyone reuse the OEM fuel filter? The walbro one seemed a little more restrictive than the OEM one.
***Well I pulled the pump out to check everything, as I expected everything seemed fine. None the less I took it apart and then put all back together the same way (checked evomoto). Fired it up, crank, then start. Left the walbro fuel filter in, cause seems like every write up I found used it.
Old Nov 4, 2006 | 12:47 PM
stance's Avatar
Tnat's interesting, I just installed mine without the kit. Now I'm paranoid, not sure if my one is also leaking fuel.
Has anyone else installed the pump without the kit and had problems?
ps. I reused the OEM filter as well.
Old Nov 4, 2006 | 12:53 PM
555R's Avatar
hmmm
tough call but i know my car blows alot of unburned fuel out now
if u did the install carefully you shouldnt have had any probs...
my car is pig rich noweverything snapped in fine
and i reused the stock filter
Old Nov 4, 2006 | 12:58 PM
stance's Avatar
Originally Posted by 555R
hmmm
How did you tell that it was leaking?
Old Nov 4, 2006 | 02:49 PM
555R's Avatar
i cant tell if it is but the car is running rich pushing out alot of fuel smoke and it stinks
when installing the kit i had to push the pump into the grommet also...did u reuse that white spacer thingie that was on the pump also?
my black rubber grommet didnt pop out of the assembly when removing the pump, only the white spacer came out which i reused
Old Nov 4, 2006 | 03:04 PM
stance's Avatar
Oh Ok, I didn't get any smoke after the install and yes I did reuse the white spacer.
Old Nov 4, 2006 | 03:25 PM
555R's Avatar
the car was running great but it was flashed without the pump
no it feels a bit weaker but it does blow out smoke which it didnt previously
or at least as much smoke
Old Nov 4, 2006 | 03:31 PM
ak47po's Avatar
I don't know why people don't buy the Walbro kit,it dosen't cost that much more than just the pump,weird.
Old Nov 4, 2006 | 03:39 PM
stance's Avatar
I didn't even know there was a kit until today. Where I got the pump from (local store in Australia) they only sell the pump itself.
Old Nov 4, 2006 | 05:23 PM
ashumo's Avatar
Well there are vendors telling you that you dont need the kit. Which is why I didnt purchase it. Point is it was the reason I was running lean @ peak tq.
Does your pump cycle when you turn the ignition to "ON."
Old Nov 4, 2006 | 11:04 PM
555R's Avatar
cycle
you mean turn the key and hear the buzz
i believe it does
Old Nov 5, 2006 | 01:34 AM
Ackerson's Avatar
I've done a few of these with the stock pieces and there was no issues with leaning out.
Old Nov 5, 2006 | 05:56 AM
ashumo's Avatar
What makes the pump cycle? Is there a relay I can test? Mine doesnt cycle...turn key no cycling pump buzz. Guess best bet would check the stock pump to see if it still cycled.
Did they have a wideband o2? Some may not have issues, considering how many people say you dont need the install kit. I on the other needed it.
Old Nov 5, 2006 | 09:59 AM
jrsimon27's Avatar
is there any problem using the walbro filter cause iam using it and yes it looks to be more restrictive then the stock one?????
i used it cause if its more restrictive i will help contaminents stay out of my pump and fuel injectors, but what do you guys think????
Old Nov 5, 2006 | 10:29 AM
555R's Avatar
what im wondering is how old is the car that the swap was done...
after a while rubber can take the shape of the original fuel pump..
meaning compresses/degrades/takes shape...
my Evo has 8k miles so its still pretty new and the pump took a bit of a push to get inplace
I would think a higher mileage pump would have a gasket that form fitted to its original pump
and swapping out a new one wouldnt fit as well...
just my 2 cents
