Hallman Pro vs Pro RX
Old Nov 8, 2006 | 08:39 AM
Doug88's Avatar
I know the differences are the ceramic ball and lighter spring but are there any downsides to either MBC?
Old Jan 24, 2007 | 04:43 PM
Jer.k's Avatar
bummp. Anyone w/ experiences w/ both? Is the RX better than the Pro?
Old Jan 24, 2007 | 05:18 PM
RenoEvo's Avatar
I believe Al from dynoflash did a case study on this. IIRC, the RX does not work as well with the evo as the regular Pro. Any other opinions? I need to order one soon..
Old Mar 11, 2007 | 02:28 PM
derangedazn's Avatar
bump to find out more info on this
Old Mar 11, 2007 | 02:48 PM
Exciting News's Avatar
No problems during the year I've had my RX. It's both smooth and precise. I've only gone up to 23.5 psi.
Old Mar 11, 2007 | 05:33 PM
tehforbes's Avatar
yea ive had my RX for over 30k miles and pushing 21lbs with no problems. its nice to be able to adjust from in-car when it gets colder outside and spikes
Old Apr 4, 2007 | 10:02 AM
boostinjuice's Avatar
bump, just bought the pro. Do i need the stiffer spring which comes with the RX kit?
Old Apr 4, 2007 | 12:08 PM
dubbleugly01's Avatar
the light spring won't control well at boost above 23#'s or so. You'll need the heavier spring. In cabin control beats the heck out of having to pop the hood to make adjustments.
Old Apr 11, 2007 | 02:47 AM
Kellendros08's Avatar
How and where would you install it inside the cabin?
Where do you drill you holes at?
Pics would be great..
Old Apr 11, 2007 | 05:24 AM
I drilled the hole through the firewall trying to keep a straight shot between the adjustment knob and controller itself. Make sure you peel back the insulating layer, or it will try to wrap around your bit.
Old May 13, 2007 | 08:29 PM
lemmonhead's Avatar
Ceramic Ball in the RX is works a lot better than the Pro metal one. From the Boost nipple resides the ball then the spring then your dial.
Evo8uk
Dec 12, 2010 04:10 PM
shrtstuff89
Oct 12, 2009 03:52 PM
JDW1479
Oct 27, 2008 02:11 PM
Dem1K
Jun 26, 2002 05:59 AM
outbreak187
30
May 1, 2002 08:35 AM
