confusion on the 35r
Old Nov 8, 2006 | 10:33 AM
big_huff's Avatar
whats so great about it im confused because you can get a 50trim and on pump gas and make a little over 400whp and then you can get a 35r and make 450 whp you spend a couple extra thousand to get 20-40 whp or is the 35r better when you put race gas? is that where it shines?
Old Nov 8, 2006 | 10:35 AM
masurie2's Avatar
it depends on what kind of dyno, on mustang dyno 50trim wont make 400whp.
gt35r is at its best if u put stroker kit or race gas.
if u planned running pump most of the time and DD ur car then probably 50trim is the way to go
Old Nov 8, 2006 | 10:37 AM
Kee1pride's Avatar
50 trim's max at around 500whp dynojet numbers where as the gt35r maxes around 650 whp dynojet numbers
Old Nov 8, 2006 | 10:39 AM
Nez136's Avatar
35r is a race gas turbo. In a LOT of cases you'll see 50 trims make more power and tq on pump gas b/c its more efficient in that boost range.
Old Nov 8, 2006 | 10:41 AM
big_huff's Avatar
ok thanks for the info guys
scott yo's Avatar
The 35R doesn't come alive until 25-26 psi thats when it shines! ifnyour goal is 450 whp then get a 50 trim with methanol! a 35R on pump usually makes 420ish and a 50 trim is around 400
Old Nov 8, 2006 | 10:50 AM
Kee1pride's Avatar
i'd have to disagree. i hear the 35r doesn't come alive till after 30psi but thats all subjective i suppose
Old Nov 8, 2006 | 10:55 AM
Nez136's Avatar
Ive seen countless people with 50 trim kits and all the supporting mods make over 410whp (w/o meth). Im not to sure about the 35r and when it "really" comes alive, but i know how similar my 3065 is to a 35r and that comes alive at 25 psi.
Old Nov 8, 2006 | 10:56 AM
deadbeatrec's Avatar
who sells a 50 trim kit? turbo trix i think but who else
Old Nov 8, 2006 | 11:00 AM
Nez136's Avatar
AMS and i forget the others.
Old Nov 8, 2006 | 11:05 AM
4Gsixty3's Avatar
if u want to run pump gas and boost around 23-24psi, the 50 trim is the best. You will get ~ 430-450whp on the 50trim on pump @23psi.
you will only get ~410-430whp on the 35R on pump @ 23psi.
so yes, on pump at 23psi the 50trim will make more power than the 35R.
Old Nov 8, 2006 | 11:08 AM
Nez136's Avatar
There is my proof^
But i do love the big turbos for high boost, there is nothing like it!
Old Nov 8, 2006 | 11:15 AM
Kee1pride's Avatar
shearer as well
Old Nov 8, 2006 | 11:16 AM
WrX Kila's Avatar
Bottom line, if you are a hiway man like me.. you will get need a turbo like the 35r. The 50 trim is a good pump gas turbo but its limited to 500whp on race gas. The 35r on the other hand can make 450+ whp on pump and meth. 500+whp on race gas. 35r all the way.
Old Nov 8, 2006 | 11:20 AM
Kee1pride's Avatar
sucky thing about the 35r is that if you want to max its potential you better look at building your bottom end =\
