Which should I buy Cams or Meth injection????
Old Nov 10, 2006 | 01:52 PM
EVO8904's Avatar
I want to know which will give me the most power for the money, BC 272 cams and valve train or Methanol injection and intercooler piping?
Old Nov 10, 2006 | 02:00 PM
ExViTermini's Avatar
personally I would buy the cams first. Then buy the alky later.
Old Nov 10, 2006 | 02:04 PM
bluebyu36's Avatar
cams u will love it
Old Nov 10, 2006 | 02:07 PM
lexat20's Avatar
meth will give you more power. I have/would do cams first. Save alky for after you do all the bolt ons.
Old Nov 10, 2006 | 02:12 PM
newbieEVO8's Avatar
+1
Old Nov 10, 2006 | 02:19 PM
ONRAILS's Avatar
cams hands down
Old Nov 10, 2006 | 02:21 PM
Pure Playaer's Avatar
cames = safe hp
meth = need failsafe to be good, lots of boost, lots of power
JsEvo04's Avatar
dude personally i would say go alk injection.....
if u get a good tune on it.
Stock cams are fine for it dont go cams until upgraded turbo...
thats what im doin noww but its up to you mane just thought i say something
Old Nov 10, 2006 | 02:28 PM
Evoryder's Avatar
Camity Cams
Old Nov 10, 2006 | 02:32 PM
boomn29's Avatar
First of all, do you have a TBE and a tune? If not; that's first and foremost!
I'd save cams personally, since you are cracking open the head and all. A lot of people do it w/o regard, but to me that's a pretty major install! Depending on your choice (264/272/280, etc) you'll see a range of gains on the stock turbo.
Meth/Alky will allow you to run more boost - and be cheaper. You're also stressing your engine more with the added boost, so factor than in.
Old Nov 10, 2006 | 02:36 PM
Warrtalon's Avatar
Ensure that you have all the regular bolt-ons first, then do the cams. After you have cams and everything else (ss o2, ported manifold, licp, tbe, mbc, bov, fuel pump, tune), then get the alky and an FMIC - IC pipes aren't important really, but you can get them with the FMIC I guess.
JsEvo, that wasn't very good advice as a newbie. Read and learn before making suggestions like not getting cams until upgrading the turbo - that's absurd.
Old Nov 10, 2006 | 02:45 PM
lcakes05's Avatar
cams then alky and a wideband warr why would some one buy a ported manifold and 02 when you will get all of that with a turbo kit later just seems like a waste don't you think.
Old Nov 10, 2006 | 02:47 PM
4WS Tuning's Avatar
cams may not give as much peak power as meth... but the closer u get to redline on stock cams ur power takes a significant drop.. with cams itll give you the jump you need to keep moving the next gear.. search for be4 and after cam dyno graphs... theyre everywhere esp now cause of the ix cams... and youll see what i mean
cheers!
Old Nov 10, 2006 | 02:48 PM
4WS Tuning's Avatar
most people dont get a turbo kit...
Old Nov 10, 2006 | 03:32 PM
EVO8904's Avatar
Sorry, I forgot that I don't have my mods in my siggy. I have a 3" TBE, 10.5 hotside, 02 housing, megan manifold, and HKS intake. I was thinking 272 cams, springs and retainers too. But, how much would that cost to install. I am working on a budget and I'm just trying to get the most for my money now. I don't plan on buying valves because that is just to much money because then I would need head studs and head gasket. Thanks to everyone for the fast responce....
